TRD_ZERO wrote:This might be tough to answer but what are the chances of my valves be bent and which valves are likely to be bent?
TRD_ZERO wrote:Any ideas on what I can check or do before I just pull the head off. Thanks
evil_si wrote:Wouldnt think the valves would make contact at only a tooth out,
Did your belt split length ways or break?
loudstealthGT-Four wrote:Did you set the tensioner correctly?
TRD_ZERO wrote:loudstealthGT-Four wrote:Did you set the tensioner correctly?
Correctly? The actual hydraulic cylinder? Or the wheel and arm/bracket?
I just bolted the cylinder on with the shaft in, pushed the wheel into place pulled the pin out and the shaft pushed the bracket tensioning the belt.
Is that not correct?
jacobrjett wrote:when you reset the hydraulic tensioner, i believe its quite easy to damage the internals if you press it too fast.
Bazda wrote:But why was the timing out in the first place.
Are you using the right crank sprocket?
20v BT and 20v ST have the markings in a diff location on the sprocket as both oil pumps on those models have the dot in a diff place.
xsspeed wrote:quite easy to drop a tooth one way or the other when you have the belt around the crank sprocket and not around the cam gears if you dont wedge a rag in and leave it - possibly the issue - slack would have been on no tensioner side then, and could have ended up a tooth out.
rollaholic wrote:did you turn the engine over by hand a couple of times before starting?
