Im sure its cut, not rolled for a standard bolt
Yes, rolled threads are stronger than cut ones.
Flannelman wrote:Major stall on this, just got off the phone to ARP. Im looking at close to $8-900US just for a single set of 10 studs made to lenght or $20-30US per stud on a run of hundred. This is only on the chance that some blanks can be found at the right lenght to save cost. This also doent include the nuts and washers!
So a quick tally up sees that for a run of 100, each set will cost on worst case of $40US each stud and 2 nuts and 2 washers. Add roughly 20% for US to NZ so thats $48... Times 10 = $480... Plus GST of 15%... gets a total of $552 each set. 10 sets to make 100 is $5520.
Thats not including postage or import duty...
Ouch, I hear my wallet crying from the car outside. Or is it me?
Flannelman wrote: On the 20V models there is a cast alloy support going from the base of the block to the gearbox. There is no room for the crank gurdle and this support.
