Superstrut Removal
Superstrut Removal
Postby spoonza6 » Tue Dec 11, 2012 6:23 pm
1991 Toyota Corolla Levin Superstrut
So...went to pick a part today to grab the ss shock from the Levin there.
Attacked it with lots of enthusiasm and low n behold it came out really easy.
Ok so get home, jack levin up and start taking various things needed, got all nuts n bolts off and go to pop the shock out and boom...stuck.
Been at it for an hour, drowned it in crc, bashed it with various tools pipes bricks wood and shoe.
Exhausted now, giving up. For now...
Can anyone tell me how to get this CSB out????
spoonza6
Postby Stott69 » Tue Dec 11, 2012 6:39 pm
Ball joint fork?
Stott69
Postby spoonza6 » Tue Dec 11, 2012 6:42 pm
Stott69 wrote:Ball joint fork?
aww yeah! where can i get me one of those?
spoonza6
Postby Crampy » Tue Dec 11, 2012 6:49 pm
Hold a bit of tension on the joint, then hit the $&#$% really hard with a big bitch hammer.don't hit the threaded part, hit the joint next to the taper.
Crampy
Postby spoonza6 » Tue Dec 11, 2012 6:56 pm
tis an awkward area to get into, will upload a pic of it in a few
spoonza6
Postby Bling » Tue Dec 11, 2012 7:53 pm
Yeah, only if you don't mind righting off the boot/ making a mess of it :?
I'd go with what Crampy says. A good shock will drop the joint out. Not hitting it hard enough if it does drop out. I've heard that's not the best option either, but I don't know of a better option haha.
Is this what you're talking about? I have no idea what a CSB is..
Postby spoonza6 » Tue Dec 11, 2012 8:06 pm
The area I'm trying to part it at is at the figure 8 on the lower arms and the point at the top above the hub
Think it's a 19mm nut on the end
CSB = c#%t s#%t b#%^h
in above pic, its stuck at hub ball joint and figure of 8
can someone come bash it off for me tomorrow?
spoonza6
Postby Bling » Tue Dec 11, 2012 8:20 pm
I don't recall having to bash that one actually, so my bashing advice is not intended for that part. It may still be the answer, but I don't know.
Postby RobertC » Tue Dec 11, 2012 8:37 pm
having done it lots of times, Just bigger hammer.
For getting the figure 8 off the lower arm i found align it parallel with the lower arm then drive a tree felling wedge between them so there is a bit of force trying to pull them apart then bash the hell out of it with a huge hammer. (bashing on the figure 8 link bit around the joint.)
As for getting the one off that is between the shock and the top of the hub carrier. Hit the hub carrier on the top edge from the front of the wheel arch (should be able to get a good clear swing at it.)
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby spoonza6 » Tue Dec 11, 2012 8:38 pm
yeah thats the funny thing, the car at pick a part today didnt need a bash it kinda just fell out and was thinking it would do the same thing today on my levin but no.
wants to be a CSB
spoonza6
Postby Stott69 » Tue Dec 11, 2012 9:10 pm
Ball joint fork can be brought at either super supetcheap or repco, tho it has a high likelyhood of stuffing the boot. I did have a clamp tool which had a fork that sliped in the joint, then a seesaw finger which pushed down on the stud when you wound a bolt opposite. Think I brought that from one of the above too
Stott69
Users browsing this forum: Bing [Bot] and 35 guests
