1 gtz 1 plate
1 gtz 1 plate
Postby phrogmodz » Mon Dec 17, 2012 11:21 pm
looking for the previous owner of this white 88 ae92gtz turbo.
Anyone know him?
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby Rob_GTZ » Tue Dec 18, 2012 9:20 am
My brother & I built it originally. Turbo motor was installed by owner after us, was in wellington at that time. Since then have seen it on Trademe from a couple of different sellers in Auckland.
Rob_GTZ
Postby Bazda » Tue Dec 18, 2012 10:57 am
My mate brought it, we put a Turbo onto it. Made 200kw atw.
Sold it to a guy who lives down the road from me.
He since replaced the ex system for a full stainless custom made one.
Also got a set of our coilovers in there as well.
To date its still going strong. Owner was considering putting a cage in it and doing hill climb events.
Postby phrogmodz » Tue Dec 18, 2012 11:56 am
Got sold to a guy down here bout 4 days ago.....
Looking for a mod list, internals mainly and whar its capable of tuned for
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby Bazda » Tue Dec 18, 2012 12:53 pm
phrogmodz wrote:Got sold to a guy down here bout 4 days ago.....
Stock 4agze 8.0:1 version still running stock ecu.
custom steam tube manifold
T3/4 500hp turbo
Link Extra injector controller for boost above 10psi.
Tuned to 18psi
6 puk clutch
turbo oil drain pump
mrp coilovers
Overall its a pretty simple turbo conversion.
Postby phrogmodz » Tue Dec 18, 2012 9:21 pm
Thanks barry,
Just wanted a heads up before i crack the engine open
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby Bazda » Wed Dec 19, 2012 8:35 am
phrogmodz wrote:Thanks barry,
I see.
It really needs a much smaller turbo! The plans were to mod it more as thats why a big one was put on.
Postby phrogmodz » Wed Dec 19, 2012 8:49 am
It aparently didint appreciate 22lbs boost.....
Limited compression now.
What do you recomend for internals to handle that turbo set up?
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby Bazda » Wed Dec 19, 2012 9:00 am
No it was only tuned for 18psi.
Just a rebuild with oem oversize pistons is all you need.
Or we can supply you forged cp pistons.
Postby d1 mule » Thu Dec 20, 2012 7:37 pm
Willies AW11 made 555 HP on standard pistons.
d1 mule
Postby Bazda » Thu Dec 20, 2012 9:59 pm
Yes thats on the 8.9:1 pistons.
The earlier 8.0:1 pistons are not quite the same in strength.
