rolla_fxgt wrote:Can you please put a big flashing light/sign on your car, so next time I'm in Auckland I can avoid driving anywhere near you.
If you can't concentrate on your overall situational awareness including what's in front of you, and behind you (hint it takes a micro second to check the reaeview mirror) then you shouldn't be on the road. And it makes me wonder how you got your licence in the first place.
spoonza6 wrote:where the hell did the brake tapping rule come from?
by the way i do not condone what that guy did at all...js
whats your thoughts on this?
sergei wrote:Simple reason - you don't own the road, and you will feel better straight after pressure from behind (tailgater) is gone. If you pull over you will reduce the risk of accident.
If you are doing speed limit it does not mean anything. You are not the police and you are not authorized to police the road.
Besides the road code clearly states if someone is tailgating you you should pull over and let them pass.
Besides, people think they are doing the speed limit, but in reality they are 10kph below, because most of the speedo's lie. Hence majority of careless drivers that speed don't get the tickets and get away with 61kph in 50kph zone. If you have calibrated your speedo you will notice this.
spoonza6 wrote:That's the thing!!! Too many people focus on tailgaters than the whole situation...as it was said before, just ignore them. But most people focus on tailgaters a bit too much.
It's very important to make sure you have a safe distance between you and the vehicle in front, so you will have enough time to stop if you need to stop suddenly.
spoonza6 wrote:If you got time to brake flash or check then you're spending too much time worrying about them than other important things.
diss7 wrote:NZ doesn't have 'fast lanes' on the motorway either. They are all 100km/h lanes. You are not in Europe/Japan/USA where this is the case.
d1 mule wrote:Wow never realised there were so many douchebags on here.
You think its ok to tailgate me if im doing the limit? Where the hell do you get off??? I dont give a $&#$% if you want to go faster than me. Pass, its Easy!
snwtoy wrote:I can't believe there are so many douchebags on here that want to enrage/provoke other drivers.
BZG|Bling wrote:Here is a quote for you Sergei, I know you love quoting shit.It's very important to make sure you have a safe distance between you and the vehicle in front, so you will have enough time to stop if you need to stop suddenly.
http://www.nzta.govt.nz/resources/roadc ... tance.html
If you can't do that as a driver, you waive the right to be treated fairly on the road.
rollaholic wrote:your rear end love tap going wrong sending them off the road into a tree to their death = ???
Users browsing this forum: Google [Bot] and 24 guests
