Soiled wrote:I've used Toda pistons, Eagle 3SGTE rods machined to fit this piston, and Todas cams/valve springs to make 275kw. My turbo choice is what held me back from pushing over the 300kw mark.
There are other options more readily available in NZ for pistons now so you don't have to go for Toda anymore (JE, Wiseco) if you wanted to do it cheap talk to Distrb he used supra pistons and machined them to fit.
Celica RA45 wrote:Al did you change your valves at all to steel
corey had a few problems ,even my race 3sge beams uses steel valves
you just dont know when a ti valve will drop its head
diss7 wrote:Dry Sump - All the fluff on the net about 3sg's having poor oiling appears to be addressed in the beams. Again, talking to Glenn/Celica RA45, he's still wet sump, 1.5G's in the corners and has no issues.
Users browsing this forum: Majestic-12 [Bot] and 32 guests
