DVSMOTORSPORT wrote:Wait..... what???? You stuck rope in your cylinder so you could undo the crank bolt?
Is this engine in the car or on a stand?
DVSMOTORSPORT wrote:Nooooooo dont burn it, it will melt into a ball, possibly go between the piston and bore, maybe melt to the valves,it will make a mess that you will need to take the head off for.
If I lived closer Id give you a hand, but I think you should try getting it out with welding wire or similar before anything else, especially sell it.
RS13 wrote:Can you heat up a wire or junior hacksaw blade, try get the knot near the hole and melt a chunk off it? You don't need to blast heat down the hole that way.
Mr Revhead wrote::?
Hopefully it wasn't at bdc about to start an exhaust stroke.
Really seems to be only two options.
Keep trying to hook it out.
Off with its head.
Go burn some of that rope elsewhere and see why it won't work in place.
With a hook I'm sure you can move it round etc and get it out. Unless it was on exhaust stroke and is jammed around the valve.
Jdawg wrote:What is the access via the intake or exhaust ports like?
If you have to tale exhaust/intake maniflod off to do the head you may be able to tease it out past the valves
Users browsing this forum: No registered users and 26 guests
