Nylon rope trick gone wrong
Postby Mr Revhead » Thu Jan 03, 2013 5:23 pm
Am waiting until any potential crying is out of the way before I put the boot in :P
Yes, defo the starter flick trick! Although last time I did that it snapped the head off the bolt :cry: however that was due to someone fitting the wrong bolt previously
Postby RS13 » Thu Jan 03, 2013 5:23 pm
You're welcome. :wink:
RS13
Postby DVSMOTORSPORT » Thu Jan 03, 2013 5:33 pm
AWESOME!!!! good to hear you got it out man.
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
Postby edwagon » Thu Jan 03, 2013 9:18 pm
Good work getting it out - 'Softly, Softly, catchy monkey' - kudos for persevering with the removal and getting it done
You have dodged a bullet!
edwagon
Postby solitaire » Sun Jan 06, 2013 9:20 am
Thanks guys :D
ok, now would be the time to give me shit about trying the rope thing :lol:
AE92, KZJ120, KDJ120
solitaire
Postby jr007 » Sun Jan 06, 2013 9:24 am
OK, Can't BELIEVE you tried the rope thing.
I would have used string....
jr007
Postby DVSMOTORSPORT » Sun Jan 06, 2013 1:21 pm
Maybe try filling the cylinder with oil next time, then put the spark plug back in. Much easier to get out, just take the s/plug out and flick the key.
I should note, I am actually joking, please kids dont try this at home :lol:
DVSMOTORSPORT
Postby solitaire » Sun Jan 06, 2013 1:43 pm
DVSMOTORSPORT wrote:Maybe try filling the cylinder with oil next time, then put the spark plug back in. Much easier to get out, just take the s/plug out and flick the key.
what about sand? would vacuum out easy...
joking
solitaire
Postby BlakeNZ » Mon Jan 07, 2013 9:51 am
The sand suggestion is GOLD!!!! ha haha.
On a more serious note,good adaption and application of my suggestion,man. do you an air compressor? perhaps hooking up a thin tube to insert into the cylinder, and blast air into it for thirty seconds MAY remove any little debris.
BlakeNZ
Postby solitaire » Mon Jan 07, 2013 11:14 am
BlakeNZ wrote:The sand suggestion is GOLD!!!! ha haha.
Yeah I forgot to mention that your post in particular got me thinking, I ended up going round supercheap, mitre10 and repco and bought anything that looked like it could help - cost all up about $90, the wife will return $40 worth of stuff i didnt use in the end :lol:
Thanks again mate
solitaire
Postby d1 mule » Mon Jan 07, 2013 12:21 pm
not having a go but you fed nylon rope into the cylinder to "bind" it up so you could undo the crank-bolt?
that seem like your asking for trouble tbh
d1 mule
Postby solitaire » Mon Jan 07, 2013 9:44 pm
d1 mule wrote:not having a go but you fed nylon rope into the cylinder to "bind" it up so you could undo the crank-bolt?
Yeah, believe it or not there are people that swear by it - personally i'm never doing it again :wink:
solitaire
Postby RS13 » Mon Jan 07, 2013 10:59 pm
He got the job done, I call that a win. If not for a couple of wayward loops of nylon then we wouldn't even be having this conversation, its' just bad luck and lesson learnt. The best way other than using an impact driver IMO is removing the starter and jamming the ring gear.. I've never had the balls to try the key flicking method! lol.
RS13
Postby d1 mule » Tue Jan 08, 2013 12:01 am
HA ive never heard of it before, just seems like a dodgy thing to do, bu as said above its fixed so win!!
d1 mule
Postby jacobrjett » Tue Jan 08, 2013 12:37 am
think everyone needs to put a 1/2" breaker bar on the bolt and wedge it into the ground and crank the starter before doing this stuff
havent done that method myself but i wish i had, trying to get those bolts off with a spinning engine is such a c**t... i think i had the sump off and had jammed a shirt between the crank and block last time i got mine off...
at least you didnt get any nuts or bolts in there!
jacobrjett
Postby ae86 » Tue Jan 08, 2013 12:46 am
http://www.tool-net.co.uk/p-363765/seal ... t-bar.html
This is what you needed... i have one at work, one of the best tools ive used.. makes short work of it.
ae86
Postby Mr Revhead » Tue Jan 08, 2013 7:30 am
:o I needs me one of those!
Postby allencr » Tue Jan 08, 2013 9:24 am
I'd still like to know how it went wrong, too little rope in the cyl, rope too thick, rope sheared off by the plug threads, lots of thick rope & just dumb luck that it tied itself into a knot?
allencr
Postby Bling » Tue Jan 08, 2013 9:42 am
Mr Revhead wrote::o I needs me one of those!
Yeah that looks handy as, might have to make one!
Postby solitaire » Tue Jan 08, 2013 2:17 pm
allencr wrote:I'd still like to know how it went wrong, too little rope in the cyl, rope too thick, rope sheared off by the plug threads, lots of thick rope & just dumb luck that it tied itself into a knot?
I *think* it was not wide enough... although if it was too wide i would have had trouble pulling it out with a grabber...
so: Possibly not wide enough rope therefore too much put down there.
solitaire
Users browsing this forum: Google [Bot] and 20 guests
