Grrrrrrr! wrote:I'm keeping my eye out for a st205 setup, there was one on tardme before xmas but the seller didn't reply to my questions, not sure how good the flow rate from a single st205 pump is, might have to double up.
Cheers Revvy, but i get teh feeling availablitly might be an issue?
DVSMOTORSPORT wrote:Im sure one of the old Mitsi magnas/diamantes had a seperate waterpump mounted at the back of the head.
Grrrrrrr! wrote:Reasons i dont want an electric one are:
1) heat, going to be very close to a hot stainless downpipe
2) pressure requirement,since the piping has to go from the back of an mr2 to the front, the pressure required will be higher than an FF application
3) I want high mass flow, so pressure requirement is going to be even higher.
4) I CBF doing a decent wiring job, since that will require me delving deeper into the previous owners hachet job, at which point i'll probably get pissed off, rip the lot out, then install a link, a motec dash/logger and be out of pocket about 10K
sergei wrote:
3) Brand new ST205 pump is a tad over $100, and flows well enough to satisfy your needs (or any other needs).
Users browsing this forum: No registered users and 39 guests
