what about sand? would vacuum out easy...DVSMOTORSPORT wrote:Maybe try filling the cylinder with oil next time, then put the spark plug back in. Much easier to get out, just take the s/plug out and flick the key.
I should note, I am actually joking, please kids dont try this at home
Yeah I forgot to mention that your post in particular got me thinking, I ended up going round supercheap, mitre10 and repco and bought anything that looked like it could help - cost all up about $90, the wife will return $40 worth of stuff i didnt use in the endBlakeNZ wrote:The sand suggestion is GOLD!!!! ha haha.
On a more serious note,good adaption and application of my suggestion,man. do you an air compressor? perhaps hooking up a thin tube to insert into the cylinder, and blast air into it for thirty seconds MAY remove any little debris.
Yeah, believe it or not there are people that swear by it - personally i'm never doing it againd1 mule wrote:not having a go but you fed nylon rope into the cylinder to "bind" it up so you could undo the crank-bolt?
that seem like your asking for trouble tbh
solitaire wrote:Yeah, believe it or not there are people that swear by it - personally i'm never doing it againd1 mule wrote:not having a go but you fed nylon rope into the cylinder to "bind" it up so you could undo the crank-bolt?
allencr wrote:I'd still like to know how it went wrong, too little rope in the cyl, rope too thick, rope sheared off by the plug threads, lots of thick rope & just dumb luck that it tied itself into a knot?
Users browsing this forum: Bing [Bot] and 29 guests
