vtec vs vvti
vtec vs vvti
Postby solitaire » Tue Jan 08, 2013 6:06 pm
I did a search and was surprised to find nothing on this.
I think its fair to say: in terms of NA engines, honda initially owned the market with vtec.
Toyota now have their own version of this crazy valve witchcraft - was there a year at which honda ceased having an advantage? or is their design still the market leader in terms of NA power and economy?
AE92, KZJ120, KDJ120
solitaire
Postby Lith » Tue Jan 08, 2013 6:27 pm
Honda if anything have made a bigger gap more recent years, IMHO. The newer Toyota 4cyl motors have more or less caught up with the motors Honda made in the mid 90s now (at least in peak power terms), but the latest Honda K-series motors just stepped things up to another level, they made them make good power in stock form - but when people start modifying them it became clear that those stock figures are with very restrained setups.
They are reliable, economical, have as wide as ever a power delivery and give VERY rewarding gains when modified. I'm not sure they have any competition - at least in the 4cyl NA area at the moment.
2007 Mazdaspeed Axela
Lith
Postby Bling » Tue Jan 08, 2013 6:44 pm
It won't come up much on here as Honda wins :P
Postby iOnic » Tue Jan 08, 2013 6:59 pm
+1 to what Lith said. And Rav4|Bling. And anyone else that speaks in Honda's favour in this instance.
Postby Grrrrrrr! » Tue Jan 08, 2013 7:41 pm
+1 to the above. Toyota builds conservatively enginered very reliable motors/cars (in general), Honda does a lot more advanced stuff, and generally its also pretty reliable. I think honda puts a lot more into R&D generally, look at some of the crazy stuff they did with bikes (22,000rpm v6 bikes in the 70's, oval pistoned NR series bikes etc). Look at Honda's involvment in motorsports.. Indycar motors, F1, bikes etc.
Grrrrrrr!
Postby Dell'Orto » Tue Jan 08, 2013 7:48 pm
2ZZGE is a very good competitor to the B18C, but yeah, K20A is miles ahead of the BEAMS motors
Postby iOnic » Tue Jan 08, 2013 8:00 pm
Postby spoonza6 » Tue Jan 08, 2013 8:08 pm
for shits n giggles someone should ask this question on the nzhonda forums haha
spoonza6
Postby phoenix » Tue Jan 08, 2013 8:22 pm
It must be said that Honda is pretty much an N/A 4 cylinder company (of which I've owned a couple), so a fair whack of their drivetrain R&D funding is directed in that area.
phoenix
Postby Grrrrrrr! » Tue Jan 08, 2013 9:08 pm
phoenix wrote:It must be said that Honda is pretty much an N/A inline 4,5 & V6 company (of which I've owned a couple), so a fair whack of their drivetrain R&D funding is directed in that area.
FTFY.
Yeah, they dont do a lot of turbo stuff, or diesel or V8s.. but who needs them when there are sweet K20A, B series etc..
Grrrrrrr!
Postby rollaholic » Tue Jan 08, 2013 9:16 pm
hondas are generally made of awesome, but for some reason are much maligned.
i mean if type Rs or S2000s came with toyota badges instead people here would be drooling at the mouth (and probably other orifices too)
Postby Grrrrrrr! » Tue Jan 08, 2013 9:19 pm
rollaholic wrote:hondas are generally made of awesome, but for some reason are much maligned.
I think the maligning has more to do with some of the owners that the cars themselves...
Grrrrrrr!
Postby diss7 » Tue Jan 08, 2013 9:20 pm
Imagine if they had've made a coupe version of the s2000!
diss7
Postby Lith » Tue Jan 08, 2013 9:23 pm
Probably worth noting that the B18C in that comparison is the US spec non TypeR engine. The majority of the B18C here are JDM which make around 180ps, and the TypeR engine is 200ps
Lith
Postby iOnic » Tue Jan 08, 2013 9:39 pm
Is the 200ps/147kw SR16VE N1 too much of a rarity to join the fight?
Postby ch4ng » Tue Jan 08, 2013 10:40 pm
Sounds like Honda's ahead if we're comparing 2ZZ's to B18's. Comparing new tech to the previous generation
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby BZG Wagon » Wed Jan 09, 2013 3:48 am
Wouldn't any major differences simply come down to the cam profiles used?
There are number of variants by Toyota from memory:
VVT
VVT-i
VVT-Li
VVT-iE
Have no idea what all the differences are - I think the latter variants also alter the timing as you drive vs. the old types simply 'switched cams'?
BZG Wagon
Postby rollaholic » Wed Jan 09, 2013 5:55 am
Grrrrrrr! wrote:I think the maligning has more to do with some of the owners that the cars themselves...
probably so, though there does seem to be a lot of 'hondas are gay' rather than 'people who have tastes akin to that of magpies and happen to own hondas are gay'
Postby Snaps » Wed Jan 09, 2013 11:14 am
BZG Wagon wrote:Wouldn't any major differences simply come down to the cam profiles used?
VVT
VVT-i
VVT-Li
VVT-iE
I wasn't aware there was a VVT? I thought they were all VVt-i?
VVT-i is variable cam timing (advancing/retarding the whole camshaft)
VVTL-i is variable valve Lift/Duration (done by using two cam lobes/profiles), note that this usually also includes a VVT-i system for variable cam timing
Compared to VTEC which is switching between mutliple cam lobes/profiles, with i-VTEC being VTEC with additional cam timing/phasing as well.
IIRC?
Cheers,
Brandon
Snaps
Postby sergei » Wed Jan 09, 2013 11:47 am
Regarding toyota VVT tech:
VVT => 20v run it simple fixed angle advance on inlet cam
VVTi => 1ZZFE, 1NZFE etc continuous variable timing of cams (lift and duration is fixed) on either inlet or both cams
VVTi-L => 2ZZGE (as far as I know the only engine that uses Lift) VVTi with a second cam profile switchover at ~5800-6000rpm, basically continuous variable timing with two cam profiles.
Valvematic => has very high potential, but not used for performance models. It has ability to vary the lift continuously, thus removing the need for throttle. This system is awesome because since there is no throttle there is no compression losses associated with throttle, and obviously no potential restrictions or response issues.
Here how it works:
http://www.autozine.org/technical_school/engine/vvt_5.html
Users browsing this forum: No registered users and 49 guests
