Techniques for removing cv nuts?
Postby siren676 » Sat Jan 12, 2013 8:44 pm
Ok so its not a toyota but a nuts a nut so it shouldnt matter.
Im trying to remove the cv nuts (29mm) off my mx5 so i can remove the axles and diff to put in my new torsen diff.
I have already knocked the punch marks back to allow the nuts to move.
Have soaked the nuts with crc quite a few times and leant on them with a 1/2" drive prybar and a 2m cheater bar with no luck.(actually broke the power bar with dad leaning on it :oops: )
Are there any other techniques that i could try or do i have to find a rattle gun?
siren676
Postby 1I1 » Sat Jan 12, 2013 8:47 pm
Rattle gun will need to be half decent by the sounds of it. I had the same problem when pulling my gearbox out. Ended up jumping up and down on the breaker bar :lol:
TRD Clicky >>Here
1I1
Postby siren676 » Sat Jan 12, 2013 8:53 pm
We tried more leverage by using 2m of plumbing pipe but the breaker bar well... broke :lol:
Think dad is going to try bring home his works rattle gun(he sells quarry machinery so it should be suitable :lol: )
Otherwise i may end up just chucking the car down the road to my usual mechanic and leaving it with them
siren676
Postby iOnic » Sat Jan 12, 2013 9:00 pm
29mm?
Postby siren676 » Sat Jan 12, 2013 9:02 pm
Yep, wierd size or something?
siren676
Postby Grrrrrrr! » Sat Jan 12, 2013 9:21 pm
Had the same problem with the mr2 axle nuts. -> Image
Solution was to go ask nicely at the local tyre shop if they could get one of their fleet service trucks to pop in. bout 10 secs with the big rattle gun (3/4" drive?) they use for truck wheel nuts and no more problems.
Grrrrrrr!
Postby iOnic » Sat Jan 12, 2013 9:23 pm
siren676 wrote:Yep, wierd size or something?
Yeah kinda odd. 3/4" rattle gun will buzz it off no worries. Don't bother with a 1/2"
Postby siren676 » Sat Jan 12, 2013 9:31 pm
Cool. Dad has told me to drop into his work and they'll hit it with the rattle gun. Depending how much stuff they have to do i might be able to do the whole swap there.
siren676
Postby rollaholic » Sat Jan 12, 2013 10:01 pm
29... where did you find a 29mm socket?
Postby siren676 » Sat Jan 12, 2013 10:08 pm
Dads toolbox :lol:
siren676
Postby 85AW20v » Sat Jan 12, 2013 10:09 pm
rollaholic wrote:29... where did you find a 29mm socket?
Maybe 30mm with a strip of sheetmetal round the inside? That's how I do mine.....
See ya
Simon
85 MR2 20v
85AW20v
Postby DeeCee » Sat Jan 12, 2013 10:10 pm
i normally stick a screwdriver in the brake vane against the caliper, grab my 1/2 strong arm and then push down. When I need to, I grab my jack handle for more leverage. And no, haven't had a brake vane break yet *touch wood
GT Four Adovansu
DeeCee
Postby siren676 » Sat Jan 12, 2013 10:37 pm
Uhh brake vane? The vents inside the brake disk?
Its got solid rear disks so that might be a little tricky :lol:
Its a 29mm made by S-K Tools
Pic of carnage
siren676
Postby rollaholic » Sun Jan 13, 2013 8:19 am
well ya learn something every day. i always thought all that small jap stuff was 30 or 32.
that bar doesnt look much chop though.
and i prefer to have someone standing on the brakes myself, or you can break the nut with the car on the ground if your wheels give enough access then jack it up to fully take it off
Postby Akane » Sun Jan 13, 2013 9:56 am
car on jack stands?
Place the bar on the ground, with socket in the nut
start it up
put it in gear (reverse for other side)
let go of clutch.....
Postby rollaholic » Sun Jan 13, 2013 10:00 am
^ do not do this.
but if you do, make a video.
Postby fangsport » Sun Jan 13, 2013 10:01 am
heaps of CRC and a decent paint stripper gun.
got a cheap as Cobra gun that delivers enough heat for stubborn nuts, but not enough heat to do damage like gas would
fangsport
Postby Quint » Sun Jan 13, 2013 10:35 am
rollaholic wrote:^ do not do this.
remember doing something similar on someones suggestion once. My god have i never shat my pants so much.
With stubborn nuts i'll get a pry bar or w/e and put it on the nut edges and wallop the shit out of it a few times with a hammer, then go back onto it with the power bar. May take a few trys with each and a lot of cussing. But the shock of the hammer can sometimes work.
Quint
Postby nz_climber » Sun Jan 13, 2013 12:12 pm
Its not a left hand thread is it by any chance?
On the sierra rear end in my lotus 7, had similar problem, other side came off easy as, took ages to work out one side was left hand, therefore had been trying to do it up tighter all day!
nz_climber
Postby pc » Sun Jan 13, 2013 1:21 pm
I bought a 3/4" set from supercheap just for this type of thing (after breaking two 1/2" bars within a few minutes). Stick a 4 foot jack handle on the end of the bar and heave on it... no problem.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
