Adjustable suspension arms
Postby Stott69 » Mon Jan 14, 2013 8:08 pm
Ive got to change the rear upper A arms on the Aristo cause of inner bush wear. How much of a con is it to have adjustable arms on a mildly lowered street car?
Stott69
Postby Dell'Orto » Mon Jan 14, 2013 8:28 pm
Probably not a bad thing, but they'll require a cert
Postby Mr Revhead » Mon Jan 14, 2013 10:03 pm
I'd say its a must have if you can't adjust it less than .5-
Postby Bling » Mon Jan 14, 2013 11:42 pm
Is the wear due to the lowering or the age of the joint? Pretty expensive option to go adjustable due to cert as mentioned.
Postby Stott69 » Tue Jan 15, 2013 6:24 am
If its cert material Ill just go tgp or up rated bushes. Think the wear is due to 20 years/250,000km of driving
Stott69
Postby Bling » Tue Jan 15, 2013 8:42 am
In that case TGP should be sweet. I thought you may have already replaced them which would mean something else might be needed.
Postby tsoob » Tue Jan 15, 2013 9:29 am
its acutally a grey area, as they are not load bearing the way the laws are written you dont require a cert, however its a common belief out there with wof guys that they need certing.
Read thru lvv and you will see.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Mr Ree » Tue Jan 15, 2013 10:03 am
Just be sure to first check the play in the balljoint on the upper arms, Scott, as replacing the bushes would suck if you then discovered the BJ was $&#$%.
Are your arms the same as the JZA80, in so much that the BJ's are a piece of the arm, and cant be replaced on their own?
wak thud gush!
Mr Ree
Postby wde_bdy » Tue Jan 15, 2013 1:13 pm
tsoob wrote:its acutally a grey area, as they are not load bearing the way the laws are written you dont require a cert, however its a common belief out there with wof guys that they need certing.
If you read the WoF manual it specifically states a modification must be certified unless it is on the list of items that don't require cert. Adjustable suspension arms aren't on the list.
Callum
wde_bdy
Postby DRFTIN » Tue Jan 15, 2013 1:20 pm
i'd be very careful telling your customers that, could come back and bite you in the ass
DRFTIN
Postby Stott69 » Tue Jan 15, 2013 5:58 pm
Mr Ree wrote:Just be sure to first check the play in the balljoint on the upper arms, Scott, as replacing the bushes would suck if you then discovered the BJ was $&#$%.
Yip, I do believe that the whole rear sub frame is the same.
Who does after maket bushes? As in Super pro bushes or Nolathane?
Stott69
Postby Grrrrrrr! » Tue Jan 15, 2013 6:16 pm
Or read the VIRM, and ignore the above incorrect advice.
VIRM wrote:Modifications
16. A modification affects a component or system that directly or indirectly affects the directional control of the vehicle, and:
a) is not excluded from the requirements for LVV specialist certification (Table 9-1-1), and
Grrrrrrr!
Postby holden_fan2005 » Tue Jan 15, 2013 6:31 pm
I struggled to find bushes where I done mine and have been told nolothanes squeak after a while.
Whole genuine arms were $200 each at trade cost.
holden_fan2005
Postby Stott69 » Tue Jan 15, 2013 8:06 pm
holden_fan2005 wrote:I struggled to find bushes where I done mine and have been told nolothanes squeak after a while.
Young guy at King lower Hutt qouted lower than that. The Ozzy boys are looking at group buying super pro bushes, may jump in that.
Doing uprated sway bars shortly while car will be off the road
Stott69
Postby Mr Ree » Tue Jan 15, 2013 11:11 pm
What price did you get for the arms, Scott? Less than $200 is pretty sharp as I believe they were $280-$300 a couple of years back from R&B
You can use superpro, nolathane, R2, or that purple brand I forget the name of :)
wak thud gush!
Mr Ree
