tsoob wrote:its acutally a grey area, as they are not load bearing the way the laws are written you dont require a cert, however its a common belief out there with wof guys that they need certing.
Read thru lvv and you will see.
Mr Ree wrote:Just be sure to first check the play in the balljoint on the upper arms, Scott, as replacing the bushes would suck if you then discovered the BJ was $&#$%.
Are your arms the same as the JZA80, in so much that the BJ's are a piece of the arm, and cant be replaced on their own?
VIRM wrote:Modifications
16. A modification affects a component or system that directly or indirectly affects the directional control of the vehicle, and:
a) is not excluded from the requirements for LVV specialist certification (Table 9-1-1), and
holden_fan2005 wrote:I struggled to find bushes where I done mine and have been told nolothanes squeak after a while.
Whole genuine arms were $200 each at trade cost.
