Excessive engine heat 4agte
Postby XSVWGN » Tue Jan 29, 2013 5:49 pm
I picked my car up today today after getting some brake work done and the gurus said that they felt the car as really hot and I'm going to have a fun summer driving it...
It has always seemed a bit hot to me but nothing too bad. The fan for the radiator switches on when its supposed to but it does seem to switch on a lot. I run a Honda civic twin core alloy radiator currently. Also run a 3inch exhaust off the turbo.
Anyone have any thoughts as to what could be going on?
Matt
2008 Kia rio - work car
XSVWGN
Postby Dell'Orto » Tue Jan 29, 2013 6:01 pm
Hard one to define...maybe get a laser thermometer and see what the radiator gets to?
Postby iOnic » Tue Jan 29, 2013 6:15 pm
Change thermostat?
Postby XSVWGN » Tue Jan 29, 2013 6:24 pm
I will look into the thermostat. Yeah it is a tricky one. Engine is using no oil or water either
XSVWGN
Postby gasman » Tue Jan 29, 2013 6:36 pm
have a look at the gaps around the radiator, if there are large gaps then make up some plates to close them up.
when i had it in the FXGT it was quite tight in there and i had no issues with cooling even on the track.
"What can possibly go wrong?"
gasman
Postby XSVWGN » Tue Jan 29, 2013 7:37 pm
So make up a heat shield you mean?
XSVWGN
Postby allencr » Tue Jan 29, 2013 7:41 pm
What problem?
Is it an unknown fact that brake work gurus, what ever they are, are the definitive database of summer time automotive interior temp knowledge?
There is nothing tricky about it.
allencr
Postby XSVWGN » Tue Jan 29, 2013 8:25 pm
allencr wrote:What problem?
Huh?
XSVWGN
Postby iOnic » Tue Jan 29, 2013 8:26 pm
General rule of thumb is ignore most things that dude ^ says.
Has some knowledge but sarcastic method of delivery makes him come across as a tool.
Postby XSVWGN » Tue Jan 29, 2013 8:39 pm
iOnic wrote:General rule of thumb is ignore most things that dude ^ says.
My thoughts exactly.
XSVWGN
Postby AE82 FXGT » Tue Jan 29, 2013 9:09 pm
XSVWGN wrote:So make up a heat shield you mean?
He means like a large shroud around your radiator, so the air from the front of the car has to go through your radiator, so there is no way around it.
A smaller shroud for you fan will help too, if you haven't got one already.
AE82 FXGT
Postby XSVWGN » Tue Jan 29, 2013 10:04 pm
Ok awesome. I will mock something up and see how I go
XSVWGN
Postby Crucible » Tue Jan 29, 2013 10:21 pm
wheres the temp gauge at and is it using coolant?
Crucible
Real Life Mechanic
Postby XSVWGN » Tue Jan 29, 2013 10:37 pm
No use of coolant and the temp gauge sits at half way where it should sit
XSVWGN
Postby Crucible » Tue Jan 29, 2013 10:40 pm
Wouldnt be too concerned then.
Crucible
Real Life Mechanic
Postby Mr Revhead » Tue Jan 29, 2013 11:09 pm
Huh?
What he means is do not trust monkeys at pitstop or midas etc.
How do you know there is actually a problem? Does the gauge run hot?
Who is the "guru"?
Postby Shrike » Wed Jan 30, 2013 7:45 am
You got a water temp gauge hooked up? (aftermarket)
If you need to borrow one I have one sitting in the project car pretty sure I can track down the wiring etc for it :p
for comparision the skyline had a 52mm alloy rad 2fans in push and one in pull sat at 82C on the motorway or at around 50km (operating temp) and got to about 95C under load up the wainui hill.
highest it got on the burnout pad was 100C, Coolent system was good for about 120C before I would get worried.
I don't trust factory temp gauges (possibly the reason I didnt run it in the skyline) ;)
Shrike
Postby Crucible » Wed Jan 30, 2013 8:16 am
why bother fitting aftermarket gauges when there is no problem to start with?
Crucible
Real Life Mechanic
Postby XSVWGN » Wed Jan 30, 2013 8:45 am
I have an aftermarket one and the standard one. Aftermarket one is more precise. I will put my turbo benie back on to try and hold onto some of that heat rather then it disbursing it.
Redhead the gurus I speak of is Damon, the owner of auto brake and clutch and the guys he has working for him.
XSVWGN
Postby Mr Revhead » Wed Jan 30, 2013 10:09 am
No idea who they are sorry.
Turbo beanie? That might help under bonnet temps.
So did they say the water temp is running hot? Or that the engine is radiating a lot of heat under the bonnet?
Users browsing this forum: Google [Bot] and 30 guests
