Excessive engine heat 4agte
Postby XSVWGN » Wed Jan 30, 2013 2:39 pm
More or less the engine is radiating a lot of heat.
2008 Kia rio - work car
XSVWGN
Postby Mr Revhead » Wed Jan 30, 2013 3:10 pm
So some brake experts reckon your car will overheat based on the heat they felt come out from under the bonnet with no hot gauges or other symptoms?
If I were you I'd just carry on driving.
Postby Boost_4_Life » Wed Jan 30, 2013 3:22 pm
BHG
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby Bazda » Wed Jan 30, 2013 3:39 pm
Engines do tend to radiate alot of heat.
Postby thegreatestben » Wed Jan 30, 2013 3:55 pm
Used to quite regularly enjoy working on my mr2 in winter thanks to it's magnificent heat radiating abilities. It was also astonishing how quick the inlet manifold would suck heat out've the head after you'd cut the engine, went from cool to the touch to burny ouchies in seconds :lol:
thegreatestben
Postby Grrrrrrr! » Wed Jan 30, 2013 5:24 pm
thegreatestben wrote:Used to quite regularly enjoy working on my mr2
Liar, nobody enjoys working on mr2s.
Grrrrrrr!
Postby thegreatestben » Wed Jan 30, 2013 6:05 pm
Mine was dreamy, 45 minute cambelts :)
thegreatestben
Postby Dell'Orto » Wed Jan 30, 2013 6:28 pm
Boost_4_Life wrote:BHG
lolmagn1t. But in all seriousness, I'd pay no attention. As stated, brake specialists commenting on radiant engine temps with no form of actually measuring it vs a NA 4AGE is hardly worth being bothered over.
Postby RomanV » Wed Jan 30, 2013 6:31 pm
thegreatestben wrote:Mine was dreamy, 45 minute cambelts :)
But how is changing 45 tiny ones any easier?!
Postby allencr » Wed Jan 30, 2013 6:51 pm
It may be a safety issue with his 3in exhaust running too close to brake lines without heat shielding.
Maybe too close to the fuel tank.
Maybe a homosexual joke about having a hot 3in tube near your butt.
Maybe a TRD thermostat to match your TRD oil cap.
Maybe it was only a remark in relation to global warming/climate change, not about the car at all.
Yep, sure could be tricky.
allencr
