Why have I lost my brakes?
Postby BZG Wagon » Wed Feb 06, 2013 8:08 pm
I seem to have lost braking ability in my Nissan Terrano.
Symptoms:
1) When I pump the brake 2 - 3 times (car running) the pedal goes hard and the handbrake light comes on. It feels similar to stopping it when the engine isn't on.
2) If I slam hard on the brakes the pedal goes (almost) to the floor and the truck gradually comes to a halt. But massively diminished braking ability.
Can't see any obvious leaks, and the fluid is completely topped up. Driving normally the brakes seems relatively normal; just hard stops or repetitive use of the brake it fails.
Any ideas?
BZG Wagon
Postby Dell'Orto » Wed Feb 06, 2013 8:11 pm
Sounds like a leaky master cylinder...unsure why the handbrake light would come on though, that's usuallly related to fluid level.
Re: Why have I lost my brakes?
Postby matt dunn » Wed Feb 06, 2013 8:16 pm
BZG Wagon wrote:the truck gradually comes to a halt.Any ideas?
I presume by that that the vehicles is a diesil of some sort?
Will be either slipping fan belt, stuffed alternator vacuum pump,
or a vacuum leak somewhere.
The handbrake light coming on means that vacuum is low as most diesil's have a vacuum switch to monitor brake vacuum.
Postby Grrrrrrr! » Wed Feb 06, 2013 8:18 pm
I'd go with failing brake booster.
Diesel or petrol? If petrol check for vacuum leaks etc, If diesel look at the alternator, the vacuum pump is on the back IIRC.
Grrrrrrr!
Postby BZG Wagon » Thu Feb 07, 2013 6:15 am
Yes it's diesel.
Will have a squiz tonight and see if anything obvious is loose or has come off.
BZG Wagon
Postby evil_si » Thu Feb 07, 2013 6:47 am
Like matt said loose alt belt or Its vacuum pump will be stuffed,
Diesels have a small pump on the back of alternator (usually) to generate vacuum for the brakes
Pull the big hose off the top that runs to the booster and see if its sucking
evil_si
Postby THA SHZ » Thu Feb 07, 2013 11:05 am
also if its rear drum brakes make sure your axle seal hasnt gone and its been leaking oil into your rear brakes , had this happen with the hilux :(
THA SHZ
Users browsing this forum: No registered users and 38 guests
