20v Blacktop - Sensor near coil?
Postby roytarolla » Fri Feb 15, 2013 1:20 pm
Hi currently wiring up a 20v blacktop in my KE70.
Does anyone know what the little sensor or what ever it is that clips on next to the coil is? Has 12v supply from the efi relay but the second wire goes back into the fuse box which I have had to bin.
Just trying to figure out where this wire needs to go now.
4AGE KE70
SR20ve Primera Wagon
roytarolla
Re: 20v Blacktop - Sensor near coil?
Postby sergei » Fri Feb 15, 2013 1:54 pm
roytarolla wrote:Hi currently wiring up a 20v blacktop in my KE70.
Grey plastic square thingy? It is a capacitor (filter). It should be connected near coil from 12V supply to coil and ground (white wire with black stripe).
Postby roytarolla » Fri Feb 15, 2013 2:07 pm
Awesome, exactly what i was after. Was trying to trace where the white / black wire went but lost it.
A ground is nice and easy to sort out.
Thanks alot.
4AGE KE70
roytarolla
Users browsing this forum: Google [Bot] and 24 guests
