3SGE gen 3 oil cooler leaking
Postby jr007 » Fri Feb 22, 2013 7:52 pm
At least that's what I think it is. Being a f**ing technical legend, i'll describe it as the round silver thingee on the block above the oil filter, with hoses connecting into a coolant manifold, and the pipes that go back into the firewall.
Soooo anyway, it's dripping a little oil, nothing big,but annoying.
Is there just a gasket under there that needs to be replaced, or is there some other common drama with the 3sGE?
jr007
Postby Grrrrrrr! » Fri Feb 22, 2013 7:56 pm
Grrrrrrr!
Postby strx7 » Fri Feb 22, 2013 8:41 pm
if its the cooler itself leaking i have a spare one.
Postby jr007 » Sat Feb 23, 2013 7:06 am
Very good, thanks guys. The cooler itself doesn't have any oil on it, it's just seeping from around the block, so hopefully the o-ring will do the trick.
I'll let you know if I need that cooler :)
jr007
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
