Does anyone in Wellington/hutt have the means to cut a female 3/8th NPT thread?
I have an alloy tank that I want to use some brass fittings on.
It has 10mm thick alloy bosses welded on, but I have NFI how to cut the thread for the brass fittings.
evil_si wrote:I have a tap to suit, but im in tauranga
If you get stuck i could send it down
Grrrrrrr! wrote:http://tradetools.co.nz/products/6576300 but at that price you'd want to use it more than once..
Would just try your local engineer, chances they already have the tap so if you drill the hole to the right size they should tap it for a tenner or so.
Lloyd wrote:Would 1.05mm between threads make it 24 TPI anyway? Something doesn't add up in the measurements
Mr Revhead wrote:I do hope he actually said shazam
Adoom wrote:Mr Revhead wrote:I do hope he actually said shazam
Yep, I remember it clearly, the sky was black and full of fire and lightning. Bunnies and rainbows were streaming out of the store, fleeing for their lives ahead of the Godzilla monster. So what do these pills do? Where am I?
