Can I cut this?
Can I cut this?
Postby Stott69 » Sun Mar 10, 2013 6:11 pm
Will load up a pic when I get home but the front reo bar behind the bumper, can I cut or modify it without legal issue? Also thhe horizontal panel under the air box?
The ali bar, want to cut the bottom and back out infront of the intercooler. Then weld in plates to change it to triangular
Stott69
Postby Dell'Orto » Sun Mar 10, 2013 6:29 pm
If its the bumper reinforcement bar then no, legally it is part of frontal impact requirements. Realistically if its tidy then you'll never get picked up on it.
Need pics to be sure though, and especially about the panel under the airbox. Have seen cars fail wofs for holes cut in that area for intercooler pipes
Postby Stott69 » Sun Mar 10, 2013 6:58 pm
Pic in first post now, will take one of the airbox area shortly
Stott69
Postby evil_si » Sun Mar 10, 2013 7:36 pm
Was told by a certifier that they cant be cut, modified or removed. Or they wont pass cert,
That said most wof places wont even know
evil_si
Postby spoonza6 » Sun Mar 10, 2013 8:22 pm
Think you can cut or modify them but air bag system needs to be removed
spoonza6
Postby Garreth27 » Mon Mar 11, 2013 12:32 am
My Altezza failed certification as I modified that to fit intercooler. Basically as said cant be cut, modified or removed however he did say as of 01/01/2013 if you remove the air bags then yes it can be modified.
Current Rides:
91 Gt Starlet - Forged 5efte Drag Toy
88 EP71 Turbo S Starlet Track Toy
99 SEX10 Altezza - Daily Driver
Garreth27
Postby MrOizo » Mon Mar 11, 2013 10:16 am
Garreth27 wrote:...however he did say as of 01/01/2013 if you remove the air bags then yes it can be modified.
I should have checked this before putting the Turbo A front vent on my bumper (requires cutting a hole into the steel of the bumper)
I was most likely going to box up the insides with steel to hopefully get a but of strength back.
So without Air Bags, modifying the bumper is ok? 8O
MrOizo
Toyspeed Legend
Postby Garreth27 » Mon Mar 11, 2013 5:18 pm
Well that's what I got told by Neil Fraser in December when I had my car taken to him for the cert.
Current Rides:
Garreth27
Postby 92mr2paddy » Mon Mar 11, 2013 6:19 pm
phew thank god i took mine off and binned (scrap :) it as it was a giant ali bar, so hopefully i geta cert once my car is done, did you remove yours altogether on our altezza?
92mr2paddy
Postby Garreth27 » Tue Mar 12, 2013 1:30 am
No I replaced it with a unmodified one. Had to have and wasn't allowed to remove it either. Couldn't be cut, modified or removed unless air bags removed after 01/01/2013 as stated. That's what I was told so I just replaced it, had front mount removed all together as it couldn't be fitted without modifying it and I got the cert and let the new owner decide if he wants to refit it
Current Rides:
Garreth27
