Convert AN sizes to metric?
Postby cat007 » Mon Mar 25, 2013 12:52 pm
Hey all
I'm after a female M16 with 1.5mm thread pitched to a hose barb - and wondering if there's a relation between the AN style fittings to the metric M16 sizes?
i.e. is am M16 the same as a -16AN?
Postby cat007 » Mon Mar 25, 2013 12:58 pm
My Google skills actually worked today - HURRAY!
Found on a website:
A #7 AN fitting is a 7/16"
A #9 AN is 9/16"
A #10AN is 10/16" or 5/8" if you reduce it.
THe -AN # is a part of a fraction in which the second # is always 16.
So that's interesting - something I didn't know. Problem being is 16mm is half way between 5/8ths (10/16ths - or -10AN) and 41/64ths.....
Wonder if -10AN will work....what's 0.2mm between friends? haha
Postby e30-323ti » Mon Mar 25, 2013 1:38 pm
That's the diameter, the TPI will not be the same as a metric 1.5
You would have found this
Down here in Wellington there is W.R. Twigg that sells all manor of fittings, like a M16x1.5 Barb.
292rwhp E30
Under Re-Construction
e30-323ti
Postby sergei » Mon Mar 25, 2013 1:44 pm
cat007 wrote:My Google skills actually worked today - HURRAY!
Found on a website:
A #9 AN is 9/16"
The thread will definitely not work. Unless you are into cross-threading thread. The only thread I was able to convert with success is 1/8 NPT to M10x1, by running a tap over it.
The hose sizes could probably fit, but where do you get metric hose from?
16mm will be slightly looser than #10AN (by about 0.2 mm). Anyway there is either choice between 15mm or 16mm in metric sizes.
Postby cat007 » Mon Mar 25, 2013 2:08 pm
e30-323ti wrote:That's the diameter, the TPI will not be the same as a metric 1.5
Thanks I've flicked them an email asking if they can supply what I need
Hunt
sergei wrote:The thread will definitely not work. Unless you are into cross-threading thread. The only thread I was able to convert with success is 1/8 NPT to M10x1, by running a tap over it.
Not so much into cross-threading - or dressing!
Postby gt4dude » Mon Mar 25, 2013 4:03 pm
-10 and -10 hose tight fit over 16mm hose barb, why not?
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
