EVO Roll Centre Correction Help
Postby CAMB01 » Mon Mar 25, 2013 11:06 am
Not a Toyota but you guys are quite knowledgable so here goes.
Who I can talk to, to get some roll centre adjusters made? or is there a kit for early EVO's available? Also bump steer correction as well?
For stock EVO 3 arms. I know there a kits available for EVO 4 onwards but the arms and hubs are different so the ball joints are different.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Shrike » Mon Mar 25, 2013 11:33 am
Pretty sure ed juniors can do custom arms etc
I know kiwi race cars can but not sure whats going on with them atm
Shrike
Postby 1I1 » Mon Mar 25, 2013 11:36 am
Hey Cam, do you know Jarred Bird? He did this to his Evo race car, might be worth speaking to him.
TRD Clicky >>Here
1I1
Postby CAMB01 » Mon Mar 25, 2013 12:37 pm
Have spoken to Jarred. He upgraded to later model EVO hubs and arms, but then went to Racefab custom arms with rose joints etc. I just want roll center adjustors at the moment.
At the moment I have to raise my car up quite high to achieve the desired bottom arm angle, but then i'm also raising my centre of gravity which isnt ideal. With longer pins on the bottom balljoints I can set my suspension lower without hurting bottom arm angle, and lowering my centre of gravity.
CAMB01
Postby strx7 » Mon Mar 25, 2013 4:17 pm
Richard Grainger has an early evo in GT something, i think Dtech in tauranga did most of the work on it, they'd be worth a ring
Postby STR » Mon Mar 25, 2013 4:20 pm
fortyone do them, but they ain't cheap. I'm assuming this is what you're after?
http://www.fortyone.co.nz/parts/show/27 ... ster.html#
82 KP60 4AGTE race car
S.T.R - Shopping Trolley Racing!!!
STR
Postby KinLoud » Mon Mar 25, 2013 4:59 pm
Macpherson strut or wishbone?
RCA's work on macpherson but no use on wishbone
Postby CAMB01 » Mon Mar 25, 2013 6:09 pm
Macpherson strut on the front
STR wrote:fortyone do them, but they ain't cheap. I'm assuming this is what you're after?
Yeah those are what i'm after, unfortunately they are a different design and are for the EVO 4 onwards hubs.
Early EVO balljoints are tapered with a thread.
CAMB01
Postby touge_ae101 » Mon Mar 25, 2013 7:01 pm
Jarred previously tried roll center adjustors you can buy off the shelf etc and they were shit. what he ended up with was nick from mag and turbo palmy setting up an adjustable height steering knuckle that accounted for the change in geometry. nick sorted out bump steer etc and it dropped 2sec off his time at manfield.
For what you spend of aftermarket parts a proper race car setup and small amount of modifications you'll prob notice more improvement in times.
touge_ae101
Users browsing this forum: No registered users and 33 guests
