AE82 FXGT wrote:Are you sure thats oil?
Could be carbon from exhaust mixed with water, which is leaking from that join in the manifold.
Check the viscosity of it, if it's like water I'd say it's an exhaust leak.
Crucible wrote:It does sound like a coil pack breaking down.
May save some time and guess work to get it scanned. Most cars will give a missfire count and show what cyl is at fault, couldnt be certain with fords though. A crook injector would probley bring on the check light as it would force the fuel trims way + or - , intermittent crook injector may not show up and electrically would prob need to be checked with a scope.
Otherwise youd have to find the problem the old fashioned way of fitting new coilpack to each cyl at a time until you find the prob. That is if the wiring, ie pow and trigger, plugs etc are fine?.
phoenix wrote:For spark plugs I just cross reference to Denso, then usually buy coppers through Mark for about $3 each.
matt dunn wrote:phoenix wrote:For spark plugs I just cross reference to Denso, then usually buy coppers through Mark for about $3 each.
Cant remember exactly,
but the genuine ford plugs from the dealer are Denso specials,
and are only about $13 each?
Crucible wrote:If the plugs are fouled it does pay to replace them rather than clean and refit as they can still play up which will throw you in the wrong direction. In the past i have fitted standard plugs to customers cars when they cant afford harder wearing platnum/Iridium types. Call repco and see if your plugs will cross over.
As far as checking injectors for leakage youll need to tee in a fuel pressure gauge and see if the pressure drops off while sitting. If It does drop crimp the regulator return just to make sure its not the reg.
IMO if you had one or two that were weaping it would still fire up straight away as the pump primes the rail almost instantly and it would still fire on other unflooded cylinders. Pretty unlikely most are leaking if they have just been cleaned, flooding engine completely.
Sounds like matt has had experiance with fords in the past, maybe go for plugs first as he suggests then go from there.
cat007 wrote:Any comments?
matt dunn wrote:First thing I suggest is buy a new set of spark plugs
gap them down to less than 1.0mm.
around 0.8 - 0.9.
Fixes 80% of BA falcon missfires.
cat007 wrote:
Any comments?
matt dunn wrote:cat007 wrote:
Any comments?
The gap is probably more important than the condition.
A new plug with too big a gap is more likely to miss
then an old plug with a small gap.
1.6mm ?? It's a wonder it hasn't also damaged the coils.
cat007 wrote:
They're Ford branded - I doubt they're original - but could be! The car's at 215km's - and was serviced by Ford up until 185km's then serviced by some 'local'.
Regapped to .85mm and she purrs like a dream.
allencr wrote:There is no such thing as copper spark plugs, only a bit in there for advertising BS.
Users browsing this forum: Bing [Bot], Google [Bot] and 21 guests
