BZG|Bling wrote:I don't see where the movement will come from in that arm? The bolts go through a tight hole do they not? So It can't move to a new location. To me, the shock / spring combo is what determines the height. Messing with other areas may change the camber etc, but I just don't see how it can go lower if the shock/spring stays the same.
Perhaps the previous springs were just shagged. You are running AE92 shocks and springs (dobi) now correct?
Mr Revhead wrote:As above, if you do it right the first time, then you are effectively doing what you are doing by "resetting" them
In other words. It's BS
Mr Revhead wrote:In other words. It's BS
BZG|Bling wrote:Might look a bit lower if it wasn't sitting on 10s
Users browsing this forum: Bing [Bot], Google [Bot] and 28 guests
