Garrett GTX4294R Size FOUND :)
Postby Shrike » Thu Apr 04, 2013 11:07 am
Hey anyone got the dimensions for one of these ?
Shrike
Postby Lith » Thu Apr 04, 2013 11:43 am
Wheel or external dimensions?
https://www.turbobygarrett.com/turbobygarrett/sites/default/files/default_images/turbogroup/drawing/Garrett_GTX4294R_800269_1.pdf
They are a 70 inducer/94mm exducer compressor (good for around 95lb/min), 82mm inducer/75mm exducer turbine.
2007 Mazdaspeed Axela
Lith
Postby Shrike » Thu Apr 04, 2013 12:51 pm
As in the physical size of the whole unit
Have a mate considering getting one and just trying to work out fitment options
Shrike
Postby Girvs » Thu Apr 04, 2013 1:39 pm
If he really wants that turbo he'll find a way to make it fit.
Girvs
Postby Lith » Thu Apr 04, 2013 4:27 pm
8O
Be nice if he means it - a lot of people here seem to over turbo their cars, nothing like another car making 400kw @ wheels with a turbo good for >700kw ;)
Lith
Postby Girvs » Thu Apr 04, 2013 6:18 pm
Lith wrote:8O
I was being nice :D
Agree with your comments regarding a wasted turbo however.
Girvs
Postby Shrike » Thu Apr 04, 2013 8:06 pm
It'll be running 30psi so not wasted :p
Shrike
Postby evil_si » Thu Apr 04, 2013 8:07 pm
They are Big and heavy :D
evil_si
Postby Dell'Orto » Thu Apr 04, 2013 9:29 pm
30psi, cute
Postby Lith » Thu Apr 04, 2013 11:31 pm
Shrike wrote:It'll be running 30psi so not wasted :p
On anything less than a 6cyl with a pretty damn angry head then I am not nearly convinced :-P
Not saying I have an issue with excessively large turbos at all lol, its just a good time to decide on what is really needed and turbo cars get a bad rep for lag etc which is largely from people choosing turbos suited to a decent amount more power than they will ever use it to make
Lith
Postby diss7 » Fri Apr 05, 2013 11:11 am
You could run a much smaller turbo than that and run 30psi.
diss7
Postby Shrike » Fri Apr 05, 2013 1:06 pm
diss7 wrote:You could run a much smaller turbo than that and run 30psi.
Not with the same amount of air flow or effiency
I dont want to get into an arguement
Yes a Gtx35 could be used but it will be off the compressor map
Shrike
Postby Lith » Fri Apr 05, 2013 1:49 pm
GTX3582R is not the next size down turbo from a GTX4294R though! Seems in NZ the only turbo options are GT35, GT42. Sometimes T04Z if people are feeling nostalgic.
Not saying you or your mate fit into that - and definitely not arguing... you've said nothing about engine type or spec, just "30psi" which could mean anything - a TD05 will run 30psi on the right motor and be a good match. A T88 could do the same on the same motor, but be a piece of shit.
I was just making sure I said my bit so that I don't feel negligent if I see yet another 2litre 4cyl with cams and a little head work making full boost at near 7000rpm and making the same or less power than a T3 based turbo could have done and resulted in a quicker more enjoyable car. If he's actually building a 550+ kw (on pump gas - or 700+kw on race gas) car, awesome! :D
Lith
Postby Shrike » Fri Apr 05, 2013 2:42 pm
Aim is full boost around 3500rpm ;) the reason for the bigger frame is at redline the turbo needs to provide around 90Lb/min or 1300cfm as the head has a high VE
plotting onto the comp map half the rev range is sitting at 80% effiency and redline is at around the 70% mark so it wont run out of puff only issue is its just sitting inside the surge line
but anyway I was asking about physical size so I could work out placement in the bay not if the turbo was suited to the engine :)
I am alittle surprised there hasnt been more flaming tbh haha
Shrike
Postby Lith » Fri Apr 05, 2013 3:06 pm
Shrike wrote:I am alittle surprised there hasnt been more flaming tbh haha
I don't know about others but you haven't actually said or done anything flame worthy by my reckoning, I make no assumptions and love awesome performance so anything that looks like it could be heading that way gets my intrigue and as such I try to add things that might be helpful, as opposed to hindering it as successful builds make me happy.
I really have to remember to stop giving a shit about randoms on forums, won't happen again here.
Lith
Postby Shrike » Fri Apr 05, 2013 3:14 pm
I wasnt meaning that in a snarky way hence the :) your input is helpful just alittle off topic hope I havent offended
Shrike
Postby rollaholic » Fri Apr 05, 2013 5:43 pm
for what its worth lith i always find your posts both interesting and informative.
so please dont stop :)
Postby Luke - BZG » Fri Apr 05, 2013 6:28 pm
rollaholic wrote:for what its worth lith i always find your posts both interesting and informative.
Same here, please don't let one guy cost us a very knowledgeable mind.
Luke - BZG
Postby iOnic » Fri Apr 05, 2013 8:08 pm
So what sort of V8/20B is it going on?
Postby Luke - BZG » Fri Apr 05, 2013 8:24 pm
iOnic wrote:So what sort of V8/20B is it going on?
A freaking amazing one, 30psi at 3,500rpm on a GT42... and anything smaller wouldn't have enough air flow or efficiency.
Lith wrote:I was just making sure I said my bit so that I don't feel negligent if I see yet another 2litre 4cyl with cams and a little head work making full boost at near 7000rpm and making the same or less power than a T3 based turbo could have done and resulted in a quicker more enjoyable car. If he's actually building a 550+ kw (on pump gas - or 700+kw on race gas) car, awesome! :D
I have a bad feeling you might have described this engine build very accurately
Luke - BZG
