I am nearly finished building another car trailer - internal deck size 4500x1900
I am stuck on what to make the deck out of - I usually use steel tread plate and weld it on but am looking at other options, partly because I am looking at having a full deck so its useful for carting other stuff.
I need to make a decision before it goes for galvanizing so I can cater for fixing whatever I end up using
Cross beams are 50x25 RHS on edge, with 525 between spans
I have looked at using 20mm T&G flooring ply, but will require extra support on the edges == weight and cost and lots extra work
I am leaning towards using boards like a truck deck, but have not had good luck finding suitable timber.
How thick would it need to be?
180x42mm T&G Retaining wall timber is well priced - kinda half joking but do I just use that? Anything wrong with it?
Anyone got any ideas?
