levinguy wrote:solitaire wrote:Stupid question but I'd need a cert after fitting wilwood brakes correct?
Yes you will need a cert unless you have a nice WOF place who will pass you
yes.
wishful thinking at this stage, but, how much for a full bolt on clutch kit for a sw20 turbo?
Prymal wrote:twin plate for a st205 baz ?
Prymal wrote:with the wilwood caliper , do they use a piston that has a dust shield ? I believe this is an issue with certing them in Australia ( hence the same with AP racing )
( im over in oz now barry , hence why you havent seen me at repco i onehunga - ended up needing life saving surgery )
its a long term goal to have bigger stoppers on the car , if i find the limitations of the 205 caliper
Garreth27 wrote:anything for a ep82 gt starlet?
