best forged piston to get...
Postby mega4a » Mon Apr 29, 2013 12:07 pm
what brand of forged piston is best to get for 4age? and were and who are the reps? or who can i go through to get lets say wisco or JE pistons.
i know toyota do brand new 8.0-1 compression pistons for $200 ea pistons
mega4a
Postby Shrike » Mon Apr 29, 2013 12:28 pm
Talk to Barry (BAZDA MRP) or for Toyota rep speak with Mark at parts@manawatu.toyota.co.nz
Shrike
Postby 4agtepwr » Mon Apr 29, 2013 9:50 pm
I'd use factory toyota ze ones if I were you. Unless you want to fork out for a custom set of CP's which unless you are chasing over 500hp will offer you no advantage at all. We pushed mine to well over 500hp on stock ze aw11 pistons and never had a problem. Find someone to tune it who actually knows what there doing and use a decent ecu and you will never have a problem!
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby XSVWGN » Mon Apr 29, 2013 10:11 pm
I have standard ZE ones in my wagon and pushed 489hp at 32.2psi.... Stay standard
Matt
2008 Kia rio - work car
XSVWGN
Postby Dell'Orto » Mon Apr 29, 2013 10:13 pm
As above, no need to buy expensive forged pistons for a turbo application - Mark should be able to do you less than $200 per piston, though rings are seperate
Postby blindnz » Mon Apr 29, 2013 10:58 pm
Are new still available for through Toyota? I thought you couldn't get them any more.
Not sure what I based that on though
iOnic wrote:Don't take me too seriously - I own an MR2.
blindnz
Postby XSVWGN » Mon Apr 29, 2013 11:01 pm
blindnz wrote:Are new still available for through Toyota? I thought you couldn't get them any more.
Last time I bought new ones they were between $74 and $84 each or something.
Matt
XSVWGN
Postby Dell'Orto » Mon Apr 29, 2013 11:14 pm
We just bought a set of 8.9:1s in .5 oversize for a customer, there are still 6 left in TNZ
Postby mega4a » Tue Apr 30, 2013 10:39 am
okay ill get a new set i guess from toyota. but what about oil squirters with the aw11 pistons they dont have the cut out is it okay just to block them up and run no oil squirters?
mega4a
Postby CAMB01 » Tue Apr 30, 2013 10:41 am
Or you could make a cutout in the skirt yourself, but would pay to balance the pistons afterwards so they are the same weights.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby mega4a » Tue Apr 30, 2013 10:46 am
that's ruff as f*** though
mega4a
Postby mega4a » Tue Apr 30, 2013 5:04 pm
got new oil pump and four pistons on way thanks guys for the help!!
mega4a
Postby CAMB01 » Tue Apr 30, 2013 9:22 pm
mega4a wrote:that's ruff as f*** though
Not at all actually, if you do it right it can look like a factory cutout. You wont be altering the skirt of the piston enough to cause a problem.
As long as the piston weights are the same afterwards.
CAMB01
Postby Bazda » Wed May 01, 2013 4:24 pm
The cutout is tiny. Can be done with a dremel or similar.
Nothing rough about it. Just sand the edges after.
You just need to measure and mark on the piston where it needs to be, cut out a semi circle from paper and trace around it, I bet you would not need to balance it after is you cut to your lines.
Postby Allister S » Thu May 09, 2013 11:00 am
mega4a wrote:got new oil pump and four pistons on way thanks guys for the help!!
I'm interested in getting some new 8:1 pistons too.
Do you mind saying how much the pistons and oil pump were (from Mark?)? Did you get 8:1 or 8.9:1?
Thanks, Al
NZ AE82 GL Liftback Tarmac Rally spec
NZ AE82 GT Liftback x 2
R32 Skyline GTS-t Type M Coupe
'07 Subaru Legacy GTB
'03 Runx 2ZZ-GE 6spd
Allister S
Postby 1I1 » Thu May 09, 2013 11:17 am
Hey Al, the pistons were $90 each and a full set of rings were $175
That was for 8.0:1 0.5mm oversize.
Oil pumps are normally $175 or $210 - seems to depend on how generous TNZ are feeling :lol:
TRD Clicky >>Here
1I1
Postby mega4a » Thu May 09, 2013 3:58 pm
all sorted then haha
mega4a
