intercooler sprayer
intercooler sprayer
Postby Stott69 » Sat May 04, 2013 12:56 pm
So Im going to use my secondary windscreen washer as a intercooler sprayer. But while testing to find an ideal mount for the sprayer I found that once primed the system would gravity feed and empty the tank. Has any one got any simple ideas I could use to fix this?
Stott69
Postby Adoom » Sat May 04, 2013 3:07 pm
The best way that I can think of to do it would be some kind of sprung check valve. With only enough spring pressure to prevent the siphoning, but the pressure from turning the pump on will open the valve.
Fish tank stuff maybe?
Or make an air leak, with a T and a one way air valve, to break the siphon.... You would loose the water already in the pipe though.
Or you need more up-hill pipe than you have down-hill pipe. You might artificially create more up-hill pipe by using bigger bore pipe for the up-hill sections.
Adoom
Postby strx7 » Sat May 04, 2013 7:54 pm
most factory headlight squirters have a check valve in them
Postby Stott69 » Sun May 05, 2013 5:51 pm
strx7 wrote:most factory headlight squirters have a check valve in them
ended up going back to p'a'p and scoring one. Just need to wire the pump to the switch
Stott69
Postby cat007 » Sun May 05, 2013 9:13 pm
Slightly off topic - but how effective is an intercooler water sprayer? When would you use it? Obviously not at the drags as any water on the track will get you in trouble...
Postby Mr Ree » Sun May 05, 2013 9:32 pm
At the track, either manually, or by way of a timer.
I have mine wired into the rear windscreen sprayer, and I just give it a twist for 10 seconds or so as I go down the back straight.
Its not really beneficial unless you are driving at WOT for extended periods.
wak thud gush!
Mr Ree
Postby Stott69 » Sun May 05, 2013 9:47 pm
Im using the secondary washer bottle, also rewiring it (with a P'a'P plug) back to my steering wheel button. As for use, Ill look into running a temp sensor on the intake.
Stott69
Postby iOnic » Sun May 05, 2013 10:01 pm
Never noticed any difference tbh. Might help if you have a really inefficient intercooler. I was running up to 25psi and even on STM's dyno (which can supposedly measure the difference in power from the alternator load on the engine when the headlights are turned on) there was no difference. The system was ECU controlled and had been retuned to make it more active.
Still, better to have it and not need it than to need it and not have it.
Postby MrOizo » Sun May 05, 2013 10:11 pm
The finer the water droplet size, the better - evaporating quicker means dropping more heat from the intercooler.
"The effectiveness of an intercooler spray is largely determined by the water droplet size – a very fine water mist will evaporate much more quickly, absorbing much more heat than a system generating large droplets. Note that this is a key point when it comes to selecting an intercooler spray pump – water spray atomisation is best with a very high pressure pump."
http://www.autospeed.com/cms/article.html?&A=111224
MrOizo
Toyspeed Legend
Postby Akane » Sun May 05, 2013 10:27 pm
I could definitely benefit from this, a short blat in the twisties sees my intake temp skyrocket to 52c, cruising temp around 31, ambient about 20.
Trust side mount. Never again.
Postby thegreatestben » Sun May 05, 2013 10:55 pm
Can't be all bad if some manufacturer's fitted them. I have my doubts at effectiveness of a washer nozzle as they don't mist the water as mentioned above. Later model car washers (specifically VE holdens) I've noticed have a much finer spray. Or use garden type dealio's
thegreatestben
Postby RomanV » Mon May 06, 2013 12:04 am
You can get misting nozzles on trademe or whatever.
Super fine nozzle, spraying out a super fine mist...
Only problem is that a tiny spec of whatever, and it's blocked.
Postby Mr Ree » Mon May 06, 2013 12:15 am
Bunnings sell the fine misting nozzles for plant irrigation systems, I just bought a selection of them and used the finest one.
Not perfect, but cost $3.20 compared to buying a HP pump and proper nozzles.
wak thud gush!
Mr Ree
Postby strx7 » Mon May 06, 2013 7:28 am
adding some form or alcohol/solvent to the liquid will; make it absorb heat from the intercooler faster.
TBH you would all probably benefit more from a digital inlet air temp guage which will give you a better understanding of how an intercooler works.
inlet temp of 51 degrees is path of the course for a turbo'd car, that isn't that bad. i have seen an inlet temp of over 130 celcius on a datalog of mine.
Postby Stott69 » Mon May 06, 2013 9:38 am
Well after a read through some of this I might look into better nozzles. Get it running first and than evolve it from there
Stott69
Postby Al » Mon May 06, 2013 11:36 am
Akane wrote:I could definitely benefit from this, a short blat in the twisties sees my intake temp skyrocket to 52c, cruising temp around 31, ambient about 20.
Change to an ATS top mount.
Al
Postby iOnic » Mon May 06, 2013 7:23 pm
Just sent this setup (minus core and joiners) to the scrapyard with the shell. Assumed no one would want shit like this nowadays :lol:
Postby matt dunn » Mon May 06, 2013 9:33 pm
Have only data logged IAT from a few cars,
My race car usually see's 25 - 35 deg IAT under full load race conditions,
but the hayabusa turbo MRS with the water cooled Intercooler see in the 40's for IAT.
I would have thought much higher than 50 and you would start running into problems.??
Postby Stott69 » Mon May 06, 2013 10:19 pm
Where did the MRS's build thread go? Havn't seen an update for a while
Stott69
Postby matt dunn » Mon May 06, 2013 10:51 pm
Stott69 wrote:Where did the MRS's build thread go? Havn't seen an update for a while
still there somewhere, hasn't been many updates, just been using it.
Will look and see.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 12 guests
