Gauges
Gauges
Postby Stott69 » Thu May 09, 2013 10:49 pm
Ive got a hole left for a gauge, but whats more important, oil pressure, water temp or oil temp? The factory dash has water temp(ish), so kind of feeling oil, but whats more important/ likely to go wrong?
Stott69
Postby CAMB01 » Thu May 09, 2013 10:56 pm
Oil pressure by far. Although usually by the time you notice it low or get a warning the damage is done. Can be a good indicator of how the engine is going in regards to its life blood.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Mr Ree » Thu May 09, 2013 11:34 pm
Agreed, OP is the first gauge you should have.
wak thud gush!
Mr Ree
Postby ch4ng » Fri May 10, 2013 12:21 am
Oil pressure.
Thats why it's always the next most common gauge on oem dashboards after speed, rpm, fuel level and water temp
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby Grrrrrrr! » Fri May 10, 2013 12:36 am
ch4ng wrote:Oil pressure.
Battery voltage is probably more common.
Grrrrrrr!
Postby 2jayzgte » Fri May 10, 2013 8:56 am
Why again he's in a stockish road car why does he need a oil pressure gauge.
If he's getting the car tuned maybe but outside of that and if everything has modified has been done correctly why bother.
2jayzgte
Postby TRD Man » Fri May 10, 2013 9:34 am
In context of the original question, your justification for your answer is a contradiction.
If this is a road car no extra gauges are important at all.
If it is a competition car of some description a water temperature gauge is much more valuable.
Water temperature is usually a constant and a gauge is an alert of any issues. If you do have over heating issues, with a gauge you can monitor them and this may enable you to continue.
Oil pressure issues are generally absolute. You're out of action. You can be alerted to oil pressure issues by a light on the dash which can be triggered well before damage is done by a range in sensors/senders.
In fact, you're more likely to respond to a light as it's 'in your face' and you can't ignore it. And if you want you can have a gauge under the bonnet.
TRD Man
Postby Stott69 » Fri May 10, 2013 10:01 am
2jayzgte wrote:Why again he's in a stockish road car why does he need a oil pressure gauge.
The intercooler thread was more for novelty value and why not, this thread is because Ive got a dual gauge pod and it looks silly with just a boost gauge. Secound gauge is realy novelty as well, but may as well be of the best use. Car will in the end be rather tickled up and some mods are just in preperation for further down the line.
Stott69
Postby Dell'Orto » Fri May 10, 2013 12:30 pm
Its an old 2JZ with a bigger turbo being slapped on, I'm sure they're good engines but I'm also pretty sure they wear out too.
Postby 2jayzgte » Fri May 10, 2013 12:42 pm
Hey Scotty you could always put the factory clock back in there mate...lol..
2jayzgte
Postby 2jayzgte » Fri May 10, 2013 12:46 pm
I'm aware of what he's got.
I just hate seeing him spend money where he doesn't need to.
I been beating up on my JZ for over a decade and have never thought to run an oil pressure gauge.
2jayzgte
Postby Stott69 » Fri May 10, 2013 2:05 pm
Bit of a different setup Coryn, gauge pod sits where the old center speaker was. Most of the novelty stuff is costing me jack all, hence why Im doing it.
Stott69
