Anybody know what sort of car these connectors are on?
Postby Grrrrrrr! » Fri May 10, 2013 4:55 pm
Need to figure out what sort of connector that is so I can order one, or go cut one off a car at pick-a-part. Only thermofan switch I could find that is at a good temp for starting the tilton pump and fan on the oil cooler.
Grrrrrrr!
Postby Dell'Orto » Fri May 10, 2013 5:02 pm
5 cylinder Honda from memory
Postby matt dunn » Fri May 10, 2013 8:31 pm
What temp is it?
Postby Grrrrrrr! » Fri May 10, 2013 8:45 pm
Its a dual switch, one turns on at 120, off at 115. the other switch is 110/105 I think it was.
Other option is to get a NTC thermistor and make up a switch circuit,which might be what I end up doing if I cant find a connector for it.
Grrrrrrr!
Postby KwS » Fri May 10, 2013 10:28 pm
Looks somewhat similar to the oil pressure switch off my old VZ Commodore with the 3.6 Alloytech
KwS
Postby fivebob » Sat May 11, 2013 12:34 pm
That particular sensor is used on a Holden Calibra, but the same connector can be found on other Holdens. I think some Barinas used a similar sensor but with a lower temp for the first switch.
Postby Grrrrrrr! » Sat May 11, 2013 12:48 pm
Sweet, google seems to confirm is a european vauxhall/GM connector, should be able to find a few astras at pick a part. Found the same fan switch with a peuguot square connector so will go out to pick-apart with the sidecutters handy shortly.
Grrrrrrr!
Postby cat007 » Sat May 11, 2013 6:15 pm
Looks like a knock sensor of a 1G supra - possibly a 7M too?
Postby Grrrrrrr! » Sat May 11, 2013 7:09 pm
All sorted, the peugoet one is a reasonable price, and I can order a new connector pigtail for $12. Now just to get the sump sorted with all these mounting bosses, bloody thing is going to look like swiss cheese once all the holes are made.
Grrrrrrr!
Users browsing this forum: Majestic-12 [Bot] and 8 guests
