Adoom wrote:So you need to move the wheels in the boot while the boot is closed?
Drive over some speed bumps way too fast.
Orrrrr, jack one side of the car up REALLY fecking high.
Orrr do some sharp turns.
Or do some hand brake turns.
Emergency stops!
But then again, the lock might just be broken
85AW20v wrote:Try pushing down on the boot lid a bit when you turn the key.....
whynot wrote:I have come across this in my cressida and mr2. you turn the key in the boot one way and it opens the boot, Turn it the other way and it locks the boot and disconnects the lever inside. my problem was I almost never use the key and it got pretty stuck in the lock position.
Possible yours has done the same?
Alex B wrote:Some Toyotas have the fuel tank behind the back seat for added lols.
Users browsing this forum: Google [Bot] and 20 guests
