Head light bulbs
Head light bulbs
Postby snwtoy » Sun May 26, 2013 7:09 pm
Hey guys, after nearly 200k I've finally lost a bulb in the dina 8)
I wouldn't mind something slightly brighter than it had/has, but don't want to be blinding other motorists.
Caldina has glass lights, so heat isn't going to damage the enclosure right?
A friend told me he got narva +100's and they were quite a bit better than standard - are they legal for road use?
I don't really care about the colour, I just want more light as I do a fair amount of night time driving on the open road.
snwtoy
Postby Dell'Orto » Sun May 26, 2013 7:10 pm
Yup fine for road use. I've had a set in my Levin for a couple of years, they're really good
Postby Snaps » Sun May 26, 2013 7:19 pm
I picked up a set of the Narva +90 bulbs for my Celica, heaps better at night than normal halogen bulbs!
Cheers,
Brandon
Snaps
Postby rolla_fxgt » Sun May 26, 2013 7:56 pm
I have plus 100's in and have used them in all my cars since the early 2000's wouldn't even think about anything else.
Would get plus 120's if they'd had them in stock when I needed them. Just so much better than standard, especially on rural roads at night. Don't dazzle people anymore than normal bulbs.
Don't go for the blue/arctic ones, I wasn't impressed with them
rolla_fxgt
Postby Bling » Sun May 26, 2013 8:23 pm
I forget now which I got, but 95% sure it's the +100 bulbs, made a good difference.
Postby Dell'Orto » Sun May 26, 2013 9:20 pm
The ones I got you? They're Plus100s
Postby wde_bdy » Sun May 26, 2013 9:29 pm
Uprade wiring with relay kit (CHEAP as off Ebay) and run plus 100's.
Callum
wde_bdy
Postby Bling » Sun May 26, 2013 9:48 pm
Dell'Orto wrote:The ones I got you? They're Plus100s
Yep those ones 8)
Postby snwtoy » Sun May 26, 2013 10:24 pm
wde_bdy wrote:Uprade wiring with relay kit (CHEAP as off Ebay) and run plus 100's.
Callum
Do the relay kits actually make a noticeable difference?
snwtoy
Postby wde_bdy » Sun May 26, 2013 10:32 pm
Absolutely, factory wiring is not up to the high drain of big wattage bulbs. Get a Toyota specific kit though as as they are wired different.
Callum
wde_bdy
Postby wde_bdy » Sun May 26, 2013 10:39 pm
wde_bdy
Postby Bling » Sun May 26, 2013 11:51 pm
What is standard wiring setup for wattage wise? Plus 100 bulbs don't use anymore than a 'standard' bulb.
Postby Snaps » Mon May 27, 2013 12:22 pm
Could always check the voltage across the bulb... If it's the same, or very similar to the battery voltage, then adding relays won't make any difference.
Cheers,
Brandon
Snaps
Postby wde_bdy » Mon May 27, 2013 9:14 pm
BZG|Bling wrote:What is standard wiring setup for wattage wise? Plus 100 bulbs don't use anymore than a 'standard' bulb.
Generally speaking standard wiring isn't up to the job, especially once it starts aging. Have seen visible improvements just with a relay kit.
Callum
wde_bdy
Postby Heylin » Tue May 28, 2013 1:41 pm
OSRAM Night eaters, buy from Aliexpress.com..50% the retail price you pay in NZ
I got some of these for the FTO..did fair bit of research and these are concluded the best in tests (compared to both Narva and Phillips).
Dont be put off the fact they are made in China...they are genuine. OSRAM manufacture anywhere but Germany these days.
Heylin
Heylin
Postby RobertC » Tue May 28, 2013 2:26 pm
The osram night breaker plus bulbs are pretty cheap on eBay Here
$25NZ posted for a pair of H4's
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby matt dunn » Tue May 28, 2013 8:20 pm
May need to check that it does actually take H4 bulbs before you go to far.
Postby Lloyd » Tue May 28, 2013 9:06 pm
Shhh, there is only one sort of headlight bulb ever :lol:
Postby RobertC » Tue May 28, 2013 11:07 pm
haha, was jsut for reference. ST215 used H7's? will say on the housing and I'm sure the OP would check what he needs.
H7's if they are correct
RobertC
Postby snwtoy » Wed May 29, 2013 8:50 pm
I bought the Osrams, in H4. Better be H4!
this page says h4 :S
http://www.powerbulbs.com/vehicles/cars ... ight-bulbs
snwtoy
Users browsing this forum: Bing [Bot] and 17 guests
