2jayzgte wrote:There's no way that MR2 looks like any sought of race car to me it just looks like a normal street car.
Mr Ree wrote:
If that is true, it reaffirms to me why I think that P.O.T need to make extinguishers mandatory in all vehicles being entered, and to initiate some kind of basic scrutineering to check for poorly presented vehicles.
Luke - BZG wrote:It would almost be worth taking a sketchy as hell car to a P.O.T event... cracked brake lines.. a bald tyre or two... an oil leak for good measure plus anything else you just wouldnt to be around a car with. Do the "self scrutineering" and park it up as you're sent out onto the track and ask everyone if they are OK with the current process.
I went to one at Manfield and the guys running it were very good, I was just expecting scrutineering and was a bit shocked that all I had to do was tick boxes and sign a piece of paper. It took away the confidence that the vehicles around me were up to a level of quality/preparedness... one guy there was at his first track day, hadnt touched his brake fluid was on standard pads and stretched road tyres... nervous...
85AW20v wrote:When you fill out and sign the entry form for P.O.T., you are agreeing that your car is up to the required standard. It's the same when you turn up to a race meeting. Scrutineers no longer - and haven't done for years - check things like the brake pedal, bearings etc. You are responsible for that as the driver/entrant otherwise the finger could be pointed at an individual if something broke that was checked.
rolla_fxgt wrote:You could try that. But bet you anything you'd be banned for life from any track or motorposrt event in the country, plus be done for knowingly signing an incorrect document.
