Cynos B idle too fast and poor heat output - thermostat ?
Postby markoneswift » Mon Jun 10, 2013 10:27 am
Hey all, I've just picked up this little Cynos B as a run about and first thing I noticed is it takes ages to warm up and the idle is ( I assume ) too high - she idles at around 1200-1300 rpm most of the time.
I'm a Toyota novice ( first time owner ) but I have a reasonable amount of mechanical knowledge so I'm thinking maybe the thermostat might be stuck open. Is this common on this age of Toyota and is it easy / cheap to fix ? Thanks !
markoneswift
Postby Dell'Orto » Mon Jun 10, 2013 10:43 am
Quite common on cars that have had little to no servicing. Cheap and easy to replace at least!
Postby markoneswift » Mon Jun 10, 2013 1:48 pm
Dell'Orto wrote:Quite common on cars that have had little to no servicing. Cheap and easy to replace at least!
Can you give me some pointers on where to get a replacement ( there's a Supercheap Autos near me ? ) and also where it is located on the 5-FHE engine ? Cheers
markoneswift
Postby Grrrrrrr! » Mon Jun 10, 2013 2:08 pm
I'd tend to go to toyota, i've never had any luck with tridon brand thermostats. Get the rubber sealing ring/gasket too.
Follow the hose going to the top of the radiator back to the end of the engine. Thermostat is inside where that hose goes back to. Two bolts to undo IIRC.
Grrrrrrr!
Postby RobertC » Mon Jun 10, 2013 3:13 pm
There is a sponsors section on the forum, have a look at the details for Toyota. (Mark will sort you out with a genuine Toyota thermostat)
This sort of shows where it is.
Passengers end of the engine.
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby Leon » Mon Jun 10, 2013 5:40 pm
agreed with the go Toyota suggestion ... more than half the time I've gone Repco bits, I've had to replace them again due them not working. Dunno why, it's only a freakin thermostat.
Postby Lloyd » Mon Jun 10, 2013 6:51 pm
3rd/4th'd for going to Toyota directly. They aren't a lot more expensive, and you should have more success. 2 bolts on the housing at the gearbox end of the head and you're done.
Postby Mr Revhead » Mon Jun 10, 2013 8:08 pm
At least Toyota will sell you the right gasket and not some generic thing that fits nothing
Postby rollaholic » Mon Jun 10, 2013 8:12 pm
thats not true, i've used those generic gaskets on an old falcon once. and maybe on like a cherokee or something :P
Postby Mr Revhead » Mon Jun 10, 2013 8:15 pm
I once fixed my old XA with wire and a hammer
Postby Akane » Mon Jun 10, 2013 10:03 pm
I had a 4E-FE Corolla, which is the same family as your cyno's 5E-FHE, which had a stuck thermostat too.
Postby allencr » Mon Jun 10, 2013 10:30 pm
I'd get Toyota thermostats IF, I also got Toyota oil, tyres, belts, batteries, filters, bearings, wiper blades and spark plugs.
allencr
Postby markoneswift » Mon Jun 10, 2013 10:47 pm
Awesome thanks for the info guys - no need to move the dizzy to get to the stat then ?
markoneswift
Postby Lloyd » Mon Jun 10, 2013 11:13 pm
allencr wrote:I'd get Toyota thermostats IF, I also got Toyota oil, tyres, belts, batteries, filters, bearings, wiper blades and spark plugs.
Toyota thermostats, spark plugs, filters and belts (in some cases) are cheaper than the aftermarket alternatives over here so it makes more sense. And the quality of the thermostats is significantly better than the other options also.
Postby AE82 FXGT » Tue Jun 11, 2013 6:22 pm
Toyota thermostats are awesome, I've had nothing but problems with Tridon thermostats (3 to be exact, I don't learn quick do I?), I'd rather pay a bit more and do the job once.
AE82 FXGT
Postby Garreth27 » Tue Jun 11, 2013 8:42 pm
no need to move dizzy to get to it
Current Rides:
91 Gt Starlet - Forged 5efte Drag Toy
88 EP71 Turbo S Starlet Track Toy
99 SEX10 Altezza - Daily Driver
Garreth27
Postby markoneswift » Tue Jun 11, 2013 9:42 pm
Garreth27 wrote:no need to move dizzy to get to it
Ok thanks mate - turns out my Cynos B has the 5E-FHE engine which is supposed to be the best one in the series isn't it ?
markoneswift
Postby siren676 » Tue Jun 11, 2013 9:44 pm
Its the best n/a E series engine, 4e-fte has a bit more power.
siren676
Postby Lloyd » Tue Jun 11, 2013 9:47 pm
5E is the 1500 varient of the E series blocks, "F" is the narrow/economy version of the twin cam head design that Toyota use, "H" is for higher compression version, and "E" defines fuel injection.
Very few Toyota engines get the H tag in their name. And yeah it's the pick of the bunch in the E blocks (without a turbo). Pretty sure the Cynos A only got the 5E-FE, Cynos B got the 5E-FHE.
Postby siren676 » Tue Jun 11, 2013 10:57 pm
Yeah i think that's right, i got my starlets 5e-fhe out of a Cynos B
siren676
Users browsing this forum: Google [Bot] and 27 guests
