Dell'Orto wrote:Quite common on cars that have had little to no servicing. Cheap and easy to replace at least!
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
allencr wrote:I'd get Toyota thermostats IF, I also got Toyota oil, tyres, belts, batteries, filters, bearings, wiper blades and spark plugs.
Lloyd wrote:
Toyota thermostats, spark plugs, filters and belts (in some cases) are cheaper than the aftermarket alternatives over here so it makes more sense. And the quality of the thermostats is significantly better than the other options also.
Garreth27 wrote:no need to move dizzy to get to it
