Exhaust manifold and Turbo gasket solutions
Postby KinLoud » Thu Jun 20, 2013 12:20 pm
What do people use for gaskets with turbo setups?
Factory gasket for exhaust manifold? (blacktop 20v to stainless turbo manifold (evilSi))
manifold to turbo?
turbo to dump pipe?
Suggestions/comments welcome
I've been trying to get hold of some SPA Gasket Eliminator and Flange Sealant - it's had some good reviews overseas
http://www.designengineering.com/catego ... ge-sealant
Repco said "we are importing some soon" about 6 months ago but no joy yet
Can't find a NZ supplier
Ken
Postby sergei » Thu Jun 20, 2013 12:23 pm
I use thin copper sheet (~1mm), works well.
Postby gasman » Thu Jun 20, 2013 12:25 pm
just use the standard gaskets. as long as your manifold and head surfaces are flat, then is should seal fine.
don't make your own gaskets using the exhaust gasket sheet for pre turbo pipes as they don't have a proper seal that goes around the full diameter of the opening and just break apart in no time.
only use sealants as a last resort IMO, if a piece of it becomes dislodged then it can do some terminal damage to your turbine.
"What can possibly go wrong?"
gasman
Postby 1I1 » Thu Jun 20, 2013 12:41 pm
Stock steel gaskets are good for manifold to cylinder head.
TRD Clicky >>Here
1I1
Postby evil_si » Thu Jun 20, 2013 1:20 pm
I use factory multilayer steel gaskets, or if needed for odd ball stuff I get stainless sheet Water cut to suit, have used copper but found it doesn't last as well as the stainless
I avoid sealants
evil_si
Postby steroidcontaskie » Thu Jun 20, 2013 4:15 pm
+1
Seems to be working for me.
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby Mr Ree » Thu Jun 20, 2013 4:20 pm
evil_si wrote:I use factory multilayer steel gaskets, or if needed for odd ball stuff I get stainless sheet Water cut to suit, have used copper but found it doesn't last as well as the stainless
I avoid sealants
Agreed. MLS gaskets have never let me down, and yep, I stay away from the goo too.
wak thud gush!
Mr Ree
Postby matt dunn » Thu Jun 20, 2013 7:12 pm
I run the factory gasket from the head to the manifold,
which is multi layer steel on the 20V's
And have tried a few different gasket between manifold and turbo,
and found the best is to machine the surfaces flat and run nothing at all.
Turbo to down pipe is V band or again no gasket from what I found.
Postby THA SHZ » Sat Jun 22, 2013 1:39 pm
I avoid sealants
this ken , Simon, where did you get my one done , was an absolute mint job and made to suit perfectly 8)
THA SHZ
Postby evil_si » Sat Jun 22, 2013 6:38 pm
Did we make one to suit yours pete?
If so would have been kev at water cutting / one stop cutting shop,
evil_si
Postby molex » Sat Jun 22, 2013 11:39 pm
Best solution for both wastegate and manifold > turbo gaskets is not to run any at all. Had manifold surface surfaced and bolted up using nordlocks, no more leaks whatsoever.
Never had an issue on the head>manifold gasket using toyota OEM multi layer steel.
molex
