ST185 GT-FOUR RC ECU same as Std GT4 ????
Post Reply
BR0Z
Post by BR0Z »
Mine has packed a sad & have one from Daniels RC in atm - pretty sure std wont work but thought I'd ask =) - If anyone has a RC ECU they want to get rid of - please pm me =)
Oldie but goodie
Mark Bros
91 GT FOUR RC x 3 1 Red (mine) Daniel - 2 White - 1 damaged & for sale =(
May the FOURce be with you
http://toyspeed.blakjak.net/profiles/profile.php?id=244
Contact:
Post by Bling »
I had a quick look on www.toyodiy.com (handy for part numbers etc)
Looks like they differ, I only picked one other GT4 off trademe though to compare.
RC:
http://www.toyodiy.com/parts/p_J_199109 ... _8404.html
A?:
http://www.toyodiy.com/parts/p_J_199008 ... _8404.html
You could always try other models, not sure if something changed between 1990 and 1991. But you can browse for all models by doing a part search.
loudstealthGT-Four
Post by loudstealthGT-Four »
RC ECU is different from standard ST185 ECU unfortunately.
But on a side note how different is the ST205 to the ST185 RC?
DeeCee
Post by DeeCee »
ST205 controls larger injectors, W2A IC system and uses MAP vs ST185 AFM (and the pin outs on ECU are in different places between the different cars and MR2 3sgte as well)
People do use st205 ECU on ST185, but requires a little tinkering to get right
GT Four Adovansu
BR0Z
Post by BR0Z »
Thought so - aparently Mechanic can send mine to some place in Nelson who fixes ECU's so might have to do that. Didn't think ST205 would work as no AFM - lucky I have the use of Dan's ECU for the moment , thanks guys
Oldie but goodie
Mark Bros
BR0Z
Post by BR0Z »
Also just realised I'm not getting e-mail notification as changed from Telecom to Vodafone & am using windowslive e-mail - so if anyone want's to e-mail me - brozie@windowslive.com cheers
Oldie but goodie
Mark Bros
DeeCee
Post by DeeCee »
find manifold outlet for MAP sensor, run map sensor + larger injectors, swap pins on ECU plug = done (i think.. never explored this in depth)
GT Four Adovansu
Contact:
Post by Boosted_162 »
Unfortunately RC ecu's are unique, which can be a bit annoying! I had the same problem with mine, is yours bringing up code 21?
The place in Nelson is Anything Electronic IIRC (I believe Brad/XS1V put me onto them) and when i called them about it they just told me i had to go through an auto electrician to get anything done.
Ended up by getting a second one off here, but my old one got repaired. Not sure who ended up doing it, but it was a contact of Gavin Bellars. Would have been $550 if i didnt get it done as a favour! (ended up being $200)
Contact:
Post by Bling »
You could try contacting Matt Dunn on here, get his thoughts.
Post Reply
