KinLoud wrote:ive run a battery out of a midsized jumper pack (900 amp - whatever that means! not a cca rating) in my racecar for ages
cheap small and doesnt care about being on its side etc.
it also takes some awful abuse!
dead flat for 1 year then recharge = happy
Mr Ree wrote:I have a solar panel mounted in the garage window which is connected to my battery, to try and help with drain through lack of use, but I plan on putting an isolator into the circuit when I have it off the road to avoid unnecessary drain, although a battery tender might be required, just to keep things happy.
I think my current battery is 380CCA, so a 400CCA NS40 'should' be enough.
There is a battery supplier out on the Petone water front that I will go and discuss things with, but Im always interested in listening to real world feedback from people who have personal experience with a product.
I figured there are a few members who are into motorsport who might have gone down the same path I am about to walk, and might have some input either good or bad?
KinLoud wrote:what car?
Supra?
fangsport wrote:if it will start a reasonbly high comp N/A carbbed engine, it'll start most things.
DexGT wrote:Do this , , its called the battery cell , across from the wharf . I got my small race car battery , motorbike and Big one for the bmw from there , the guy who runs it is very helpful / knowledgeable and the prices are sharp
holden_fan2005 wrote:http://www.batterydirect.co.nz/vertex_drycell_battery.htm
I've got one of those in the crx and keep it on charge with one of these when it's parked in the garage: http://www.trademe.co.nz/motors/boats-m ... 125523.htm
They are a small battery, could probably fit it in the glove box if you wanted to No issues with mounting inside the cabin and how it's mounted.
Mr Ree wrote:holden_fan2005 wrote:http://www.batterydirect.co.nz/vertex_drycell_battery.htm
What model did you get? I will take those specs to the place in Petone and see if they have something equal or better suited, for cheaper hehe.
Do you have a permanent female plug for the battery tender, somewhere in the car?
EDIT: KinLoud...thats exactly what I was thinking. Behind every branded sticker is a part number lol
Users browsing this forum: Google [Bot] and 42 guests
