Lloyd wrote:In all honesty, you're wasting your time trying to clean it with the manifold on. Take the whole thing off, let it soak in brake cleaner and scrape as much off as you can with a screwdriver. Most of the intake cleaners for the dry side do very little.
phoenix wrote:Nulon foaming engine cleaner is at SCA and Repco. Similar stuff and in a similar size can to the Subaru Upper Engine Cleaner.
The Subaru stuff you spray throttle plate and then into the intake manifold (partly while running, partly not). The Nulon stuff tells you to that plus pull the spark plugs and give it a shot in there.
I used the Nulon stuff on a vvti 1JZ-GTE which used to occasionally ping on BP 98 - even on stock boost. After using the stuff, and pulling the plugs to clean pistons etc, I haven't heard it ping since.
rollaholic wrote:everyone who buys those is pretty much subsidising landrover owners
Users browsing this forum: Google [Bot] and 32 guests
