Lloyd wrote:It generally makes no difference to cooling. And loop it.
Grrrrrrr! wrote:why remove the heater core? is it leaking, or are you stripping it out for racing?
matt dunn wrote:Lloyd wrote:It generally makes no difference to cooling. And loop it.
It generally makes no difference,
and don't loop, it block it.
Looping it lets water circulate bypassing the radiator with losing heat,
so the cooling system looses efficiency.
suprra_girl wrote:You will need to keep the hoses going to the throttle body as they warm it up, as for the heater hoses you can generally just loop them, I'm not sure what engine you have so can't post specifics.
edit: oh sig lol, still doesn't help me, I don't know how those engines route :p
jondee86 wrote:I've got a feeling that you need a heater for a WOF. Something to
do with de-misting the screen if I remember rightly.
Cheers... jondee86
5.11 Windows: shall meet the following requirements;
(3) The front windscreen shall have an effective method of demisting, either by ducting of air, hot wire elements, or have an anti-fogging coating applied...
Lloyd wrote:Since when? (genuine question, never seen it in the VIRM)
suprra_girl wrote:... as for the heater hoses you can generally just loop them.
Users browsing this forum: Google [Bot] and 34 guests
