Okay, so after getting throughly pissed off at how shit gen 2 3sgte fuel rails are, I found a top feed rail from a 3sfe that has the same injector spacings, so now i just need to make mounting brackets.
But I dont have top feed injectors yer or want to buy the injectors yet, so my question.. are all 11mm top feed injectors the same basic dimensions? (oring-oring length and bottom oring diameter are the important ones i guess?) in which case i can go grab some 4afe or similar econobox injectors from pick-a-part to mock things up with. Or do they tend to vary a bit in which case I better figure out exactly what i'm going to buy and get on with it.
Numbers i found were 11mm top bore, 63.5mm oring to oring (centreline) or 60mm between the grooves. and 16mm OD of lower o-ring
