3SGTE CT26 CT20b Exhaust housing
Postby loudstealthGT-Four » Sat Aug 24, 2013 11:51 pm
Just wondering if there are any difference between the CT26 and the CT20b exhaust housing on a 3SGTE.
As I am planning on increasing the size of the factory wastegate ports, have three spare CT26's in the garage that i can use the exhaust housing off, if they'll work?
Tyler
loudstealthGT-Four
Postby gt4dude » Sun Aug 25, 2013 2:05 pm
different, ct20b exhaust side is alot better for spooling, i think the exhaust wheel is slightly smaller, and the housing flows better through the wastegate ports
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby iOnic » Sun Aug 25, 2013 2:46 pm
Ct20b has a smaller exducer on the turbine. To fit the 26 turbine housing on a 20 you would have to add metal and reshape the housing to suit the 20 turbine wheel profile
aka too hard basket
Postby loudstealthGT-Four » Sun Aug 25, 2013 2:51 pm
Ah bugger, was hoping to just get it done then swap the housings over.
To hard basket indeed.
Thanks Tyler
loudstealthGT-Four
Postby iOnic » Sun Aug 25, 2013 2:53 pm
You can swap the housings over if you use the turbine wheel to match the housing but then you don't have a ct20b anymore :lol:
Postby loudstealthGT-Four » Sun Aug 25, 2013 2:57 pm
iOnic wrote:You can swap the housings over if you use the turbine wheel to match the housing but then you don't have a ct20b anymore :lol:
Haha yea ill swap out my good steel turbine wheel for a premium grenade ceramic wheel......
loudstealthGT-Four
Postby loudstealthGT-Four » Sun Aug 25, 2013 2:58 pm
That will most likely sort my boost creep issues too..... :wink:
loudstealthGT-Four
Postby 92mr2paddy » Sun Aug 25, 2013 5:59 pm
weld up internal gate and use external wastegate, never have boost creep again.
92mr2paddy
Postby loudstealthGT-Four » Sun Aug 25, 2013 6:42 pm
Had considered that, but with the cost of welding an external to the factory cast manifold properly, which was about $250-300 and then the cost of a new wastegate, it just wasn't worth it to me.
loudstealthGT-Four
