hot start issue
hot start issue
Postby Stott69 » Sat Aug 31, 2013 2:09 pm
Hey guys. Cars having an issue with starting when hot. Will turn over but not fire. Have checked and can hear fuel pump running. Starts from cold fine and will run for hours, but as soon as you stop and turn the car off it wont fire back up. Let it cool and its fine again.
Where should I start?
Stott69
Postby jbod » Sat Aug 31, 2013 5:47 pm
What car and engine is it? Any reason you think why it may be starting to be like this? Ie potentially worn, low compression?
jbod
Postby Stott69 » Sat Aug 31, 2013 5:58 pm
Toyota Aristo. 255000km on the clock, so worn something, but not sure what? Im hoping its electrical and a easy/cheap fix as dont realy want to do a refresh for a year.
Stott69
Postby strx7 » Sat Aug 31, 2013 5:59 pm
turbo or not?
Postby allencr » Sat Aug 31, 2013 6:08 pm
Tried it with the throttle half way down?
Injectors dribble a little from residual pressure, more air helps starting up with that extra fuel.
allencr
Postby Stott69 » Sat Aug 31, 2013 6:14 pm
Yes running 10psi, stock ecu & injectors.
Yes have tryed pushing the gas pedal but to no help
Stott69
Postby jbod » Sat Aug 31, 2013 7:36 pm
Well hopfully electrical, maybe check the basics like compression if you feel the engine is gettin tired. Do you have a workshop manual for the aristo? From my experience its often little help people firing off it could be this and that; best to work your way through the manual troubleshooting section so you can rule out components one by one
jbod
Postby strx7 » Sat Aug 31, 2013 7:59 pm
if you turn the key on for 5 seconds then off, then on for 5 seconds, do this a few times then try starting it, what happens?
Postby Shrike » Sat Aug 31, 2013 8:27 pm
I had a similar issue in my R32 with a Rb25 running the rb20 fuel pump
Have you replaced the fuel pump?
It could be running but no providing enough pressure for the injectors
Shrike
Postby gepsk8 » Sat Aug 31, 2013 11:45 pm
Check basics first compression test when cold and when hot.
O272754663
gepsk8
Postby Crucible » Sun Sep 01, 2013 10:11 pm
When its upto temp pull pump fuse/relay and let it stall.
Replace it and start straight away, does it fire now?
CTS maybe out of range also, ie cold voltage to ecu when hot = more fuel. Test or replace.
Crucible
Real Life Mechanic
Postby Stott69 » Sun Sep 01, 2013 10:19 pm
Cool, few things to check when I get home. Will need to borrow a compression tester tho
Stott69
Postby Crucible » Sun Sep 01, 2013 10:48 pm
jbod wrote: its often little help people firing off it could be this and that; best to work your way through the manual troubleshooting section so you can rule out components one by one
Logic and evidence. You are very correct my friend.
Crucible
Real Life Mechanic
Postby Stott69 » Sun Sep 22, 2013 2:24 pm
Bringing this back up as Im now home and can test stuff. Have pulled codes and Im getting 25: Air-Fuel Ratio Lean Malfunction. Posibly looking at the ignitor? how could I test it?
Stott69
Postby Crucible » Sun Sep 22, 2013 6:30 pm
vacuum leak, low maf output, low fuel pessure.
Crucible
Real Life Mechanic
Postby Stott69 » Sun Sep 22, 2013 8:22 pm
Easyest/cheapest way to check fuel pressure?
Stott69
Postby iOnic » Sun Sep 22, 2013 8:34 pm
Jam a gauge on
Postby allencr » Sun Sep 22, 2013 10:46 pm
I'd skip the fuel pressure if it's idling OK, redlines 2nd or 3rd, and/or stalls when the FPR return is pinched.
Not just 'pushed' the pedal, but holding it down 1/2 to WOT when starting.
//Does it or does it not spark when it isn't starting?????????????
The plugs will be wet & exhaust smell of fuel if the ignition isn't working, and will be dry if there's a fuel problem. Not a pump problem because you already know it works well, but something that may fail when hot like its relay.[/b]
allencr
Users browsing this forum: Bing [Bot] and 36 guests
