GDII wrote:With all the tools and parts I'd need to buy to rebuild the current engine I'd be better off upgrading to a GEN 3. But I'd need a good one with known history.
jaypines wrote:if you want to proceed changing the valve seals without taking the head off, you will need this tool or something similar. i think you cannot use a regular valve spring compressor for the 3sg head due to space limitations.
jaypines wrote:if you want to proceed changing the valve seals without taking the head off, you will need this tool .....
GDII wrote:...smokes quite abit when cold. I suspect valve seals. Would getting a compression test done be best to rule out the piston rings?
Users browsing this forum: Google [Bot] and 26 guests
