GDII wrote:You should be able to pick up OEM Bilsteins for a good price off Mark.
Are you saying your TRD suspension has Bilstein shocks in them? Which are different to OEM struts?
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC wrote:you might have the exact specs already but if not
damping force at 0.3m/s of piston speed
Front shock absorber 4292/1029N Fixed rate Made by BILSTEIN
Rear shock absorber 2538/637N Fixed rate Made by BILSTEIN
Front Lowering Spring K=107.8N/mm
Rear Lowering Spring K=92.1N/mm
touge_ae101 wrote:alternatively autolign rebuild bilsteins through their sister company racelign. good job and turn around at a reasonable price. iirc price for rebuilding/revalving bilsteins was around $170 a shock which i think is reasonable.
Mr Ree wrote:Thanks for the offer, do you know how much the HD version differ to the typical yellow bilsteins found in the RZ's?
Users browsing this forum: Bing [Bot], Google [Bot] and 41 guests
