Inline oil filter for turbo
Postby ~SlideWays~ » Mon Sep 09, 2013 1:46 pm
Hi all,
I've had a turbo die after a run bearing, so have replace the turbo but now thinking it might be worth fitting an inline oil filter to the oil feed line, especially since the engine is just about to start the run in km's.
Has anyone used one or have suggestions of suppliers?
What sort of micron rating should it have for a journal bearing turbo?
There are two on Trademe but no indication of a brand or quality.
~SlideWays~
Postby strx7 » Mon Sep 09, 2013 4:06 pm
subaru use a gauze filter from std in a lot of their later motors, and its the prime cause of their turbo's dieing and it gunges up and blocks flow all together, so I'd be very careful about fitting a filter pre turbo myself
Postby loudstealthGT-Four » Mon Sep 09, 2013 4:19 pm
I wouldn't think it'd be nesscecary, doesn't the oil pass through the oil filter before it goes through the turbo?
loudstealthGT-Four
Postby ~SlideWays~ » Mon Sep 09, 2013 4:33 pm
strx7 wrote:subaru use a gauze filter from std in a lot of their later motors, and its the prime cause of their turbo's dieing and it gunges up and blocks flow all together, so I'd be very careful about fitting a filter pre turbo myself
That's interesting, in my situation the car gets an oil change a lot but as a precaution I could just take the filter off and clean it (if it can be).
loudstealthGT-Four wrote:I wouldn't think it'd be nesscecary, doesn't the oil pass through the oil filter before it goes through the turbo?
I did think that but its tee'd off the block where the oil pressure sensor is on a 4age, I'd assume that is after the oil filter else the sensor wouldn't last long (tiny hole) but I don't know for sure.
~SlideWays~
Postby allencr » Mon Sep 09, 2013 6:52 pm
Directly from the sump to pump to relief valve to filter to whereever in any wet sump engine you'll see.
It needs a turbo that doesn't conduct 175C+ heat into its bearing & lube when shut down, not a filter.
It needs lube that can take HIGH temps without gumming up OR a cool down period so the lube inside it doesn't get baked, take your pick.
allencr
Postby Dell'Orto » Mon Sep 09, 2013 7:18 pm
Common upgrade for XR6 turbos as their factory turbo feed gums up and kills the turbo, but I don't think they're particularly necessary for your car Gav.
Postby AE82 FXGT » Mon Sep 09, 2013 8:33 pm
Dell'Orto wrote:Common upgrade for XR6 turbos as their factory turbo feed gums up and kills the turbo, but I don't think they're particularly necessary for your car Gav.
XR6 turbo and Territory Turbo both run gauze filters inside banjo bolts for the oil feed from the block, as mentioned above they get a bit gummed up, block the flow, and kill the turbo by starving it of oil.
AE82 FXGT
Postby Stott69 » Mon Sep 09, 2013 9:36 pm
For the gumed up filter, could take pressure differenial over the filter, high reading equals blocked filter. Its one of the auto checks we use at work
Stott69
Postby gepsk8 » Tue Sep 10, 2013 1:54 am
I would personally talk to Wade at diesel & turbo.
See what he recommends, very clued up guy.
O272754663
gepsk8
Postby ~SlideWays~ » Tue Sep 10, 2013 4:49 pm
Cheers all, I think I'll just run with out one.
~SlideWays~
Postby Mr Ree » Tue Oct 15, 2013 9:34 am
Or just clean it each time you change your oil.
Seems fairly simple to clean out the Forced performance filters :)
wak thud gush!
Mr Ree
