Stott69 wrote:So Ive pulled the plugs out of the Aristo (2jzgte single @ 10psi). They're a little oilly but main thing is the gaps look huge, like up to 3mm. I take it this is huge?
Stott69 wrote:Yip. Fault code that I pulled was 25, which could be ignition, hence checking plugs.
Stott69 wrote:Oh and eyeomiter is out, plugs look to be about 1.5 against a rule. Will regap once I get feeler gauges.
