I have been reading alot about these, both good an bad, and was wondering how many, if any, of you are running pre turbo filters in your feed line, on your turbo(s)?
I know that alot of the Garrett snails in the Ford Falcon XR6 died an early death, due to the filter screens clogging up, and given that was an OEM item, one would think that they might have got the screen mesh size wrong, as surely all of the failures couldnt be down to owner neglect/lack of oil changes?
Also, you would think that they could have easily built in a reasonable amount of idiot proofing into the system, like a bypass that opens if the pressure drop across the filter is too high.
Anyway, I have medium term plans of running a PTE CEA 6266 DBB snail, and Im considering buying one or possibly even two of these and running them in parallel, and was wondering if anybody here had any first hand experience with them, how long they take to get remotely dirty, or even, if there is something else on the market you would recommend?
http://store.forcedperformance.net/PROD ... ilter.html
Any advice/help/info appreciated
